engine compression tester instructions needed
Old Oct 4, 2007 | 09:56 PM
hiwords's Avatar
Default engine compression tester instructions needed
ok so i got a engine compression tester and all i kno is u take out one of the plugs and replace it with the tester. so do i have to test each cylinder? are the numbers sopposed to be 1.2-1.6 bar at idle and 2 bar at 2k rpm?
also how am i going to get the tester into the plug hole? the hole is like 8 inches deep
Old Oct 5, 2007 | 12:17 AM
acetrebo's Avatar
Default RE: engine compression tester instructions needed
You need a tester with a long hose extension to get down into the hole.
You had better read up on the process to do this test.I can tell from your post that you have no idea how to do a compression test.
Buy a haynes manual and follow the instructions. You remove all the plugs, unplug the fuel relay, block the throttle open, and turn the engine over. The test needs to be done with the engine up to normal temp, etc, etc, etc.
The $15 dollars for a haynes manual will give you invaluable information, and all the knowledge you need to do a test like this properly.
good luck!
tpaudi
Nov 13, 2011 06:17 PM
harveg
Oct 6, 2010 11:59 AM
frostynews05
Jul 8, 2009 01:01 PM
APRII_BlackonBlackA4
Jun 24, 2007 11:07 PM
kchao2000
Apr 11, 2005 08:34 PM
