engine light
Old May 12, 2007 | 03:37 PM
dam's Avatar
dam
Default engine light
I have a 99 a4 2.8. The engine light came on and I pulled 4 codes. I would appreciate any help or explanation. The codes are p0332, p0455, p0118, p1138 thanks.
Old May 12, 2007 | 03:48 PM
techbod's Avatar
Default RE: engine light
P0118 coolant temp sensor or wire short to ground
P0332 insecure/poor wiring connectionknock sensor bank 2
[hr]
P1138 long term fuel trim, idling bank 2 ( probably caused by the other problems ).
edit: P0455 large leak detected EVAP system
Old May 12, 2007 | 03:53 PM
dam's Avatar
dam
So I'm possibly looking at an electrical/wiringproblem. I'll check wiring around coolant reservoir. What else should I look for.
Old May 12, 2007 | 03:58 PM
techbod's Avatar
the last code is the most important ( large air leak ) and probably responsible for the rest so check all the pipes to the intake and from the EVAP purge valve
Old May 12, 2007 | 04:01 PM
dam's Avatar
dam
thanks for the info. I'll check all lines, hopefully I'll find something.
Old May 13, 2007 | 06:01 AM
dam's Avatar
dam
where is the evap purge valve located?
Old May 13, 2007 | 07:43 AM
techbod's Avatar
[IMG]local://upfiles/12092/3DFF27ACAF824D94B77ED6C6C28B773B.jpg[/IMG]
Old May 13, 2007 | 11:00 AM
CRAZYHAWK's Avatar
P0455 > Gas cap loose
Old May 13, 2007 | 09:43 PM
drp1489's Avatar
i recently had the fuel trim code after an inspection. i repaired 2 vacuum hoses that were cracked and the problem was solved. look over all hoses for cracks, loose fit etc.
