Engine Ping (knock)
Old Oct 23, 2006 | 02:41 AM
sjoudeh98's Avatar
Default Engine Ping (knock)
I have a 96 v6 a4 with 111,000 miles. I already tried new spark plugs and wires, no help. This is a ping as if you put low grade gas into a high performance engine. I use the highest pump 91 octane only. Any Ideas?
Old Oct 23, 2006 | 02:55 AM
wood_e's Avatar
Default RE: Engine Ping (knock)
Check your DTCs and try replacing your knock sensor. ONn modern FI cars a knock sensor changes the timing so there's no pinging. Replace the knock sensor and see what hapepns.
Old Oct 23, 2006 | 03:16 AM
sjoudeh98's Avatar
Sorry for the noobster question but what are DTC's? And how can I check the knock sensor? Do I just have to replace it and see if it fixes the knock problem?
Old Oct 23, 2006 | 09:13 AM
david9999's Avatar
DTC (diagnostic trouble codes) are engine codes. Get your car scanned at autozone and post the codes here.
Old Oct 23, 2006 | 01:16 PM
XSive's Avatar
I have the same problem-
no codes showed on scan-
however mine acts like the knock sensor is pulling the timing back-
if you give a hard shift, you hear the ping, and the car seems to die/ dead pull just no real power-
1. does any one know where the knock sensor is located- 01' A4 2.8l 30v Quattro
2. if it is the knock sensor, will that actually cause a ping (i guess by retarding the timing too much or when not needed?)
3. any way to loop or by pass knock sensor to test?
actually thought about geting w/ someone on the VAG-COM Locator list about advancing the timing +5 deg to see if it helps-
Old Oct 23, 2006 | 01:18 PM
XSive's Avatar
hey wood_e,
what rims are in your signature line on the audi?
- i think i have a set - just wondering if the offset is the same, and the center bore?
Old Oct 23, 2006 | 01:46 PM
wood_e's Avatar
ORIGINAL: XSive
hey wood_e,
They're 17x8 Mille Miglia Rims and they have an offset of ET35 with a 5x112 bolt pattern. I don't have much more info on them as I got them used.
Old Oct 23, 2006 | 01:50 PM
CRAZYHAWK's Avatar
There could be carbon build up on valves and pistons. Try a fuel additive
like SeaFoam.
JasonDillard
Dec 24, 2017 02:26 PM
pbbg
Dec 2, 2013 10:05 AM
dochugh
Dec 5, 2010 05:15 AM
DCVING
Jul 3, 2008 07:57 PM
andrei
Sep 21, 2007 05:08 PM
