engine problem: misfire
Old Jun 17, 2006 | 07:36 PM
specialK4's Avatar
Default engine problem: misfire
this question is for a 1996 2.8 A4
ok so i recently had a problem with the rpms jumping and the car shaking etc.. i had a CEL and two codes came up and one was something to do with the EGR valve which i replaced 3 days ago. the other was a misfire. As well as replacing the EGR valve i replaced all vaccum lines. this fixed the CEL and all the problems i was having with acceleration lag etc etc... but when i start my car it still shakes on start up a little. the rpms are idling a little over 1k , its not a constant shake just on and off, not too violent either just noticable. once it warms up the shake is gone, and the rpms idle at about 300-500. so im thinking this is either 1. spark plugs. 2. spark plug wires 3. coil pack??? thats all i can think of right now any help would be appreciated. also i just replaced all spark plug wires with bosche wires today and the shake is still there. next step im gonna replace all of the spark plugs, hopefully i dont have to replace the coil packs.
so once again any help appreciated im just looking to see if anyone has had this problem before? and what to do to fix it.
thanx!
Old Jun 17, 2006 | 07:47 PM
ejc317's Avatar
Default RE: engine problem: misfire
i have that in my 03 a4 as well - check ur plugs and coils
it was bad before but after dealer replaced my coils its a bit better ... i just figured it was turbo
also its worse on cold days
Old Jun 19, 2006 | 08:00 PM
specialK4's Avatar
still have the problem after replacing wires, just bought 6 new NGK double plat plugs and they're going in tomorrow hopefully this fixes the problem. anyone else have any input?????
please help this vibration is killin me. im begining to think bad things about audi
Old Jun 19, 2006 | 10:51 PM
david9999's Avatar
Re check for codes and post the code numbers.
Old Jun 20, 2006 | 12:19 AM
wood_e's Avatar
X2 on the code check... your coils may be bad, but post the codes so we know what's going on.
haydn
Apr 21, 2014 07:03 PM
BHAudi
Jan 8, 2010 02:56 PM
Dropshotdude
Oct 8, 2008 11:32 PM
latif
Dec 30, 2006 12:42 AM
dwkent
Apr 15, 2005 07:12 PM
