Engine shakes at startup
Old Mar 21, 2007 | 10:23 PM
2KA4's Avatar
Default Engine shakes at startup
recently my car has been shaking when i cold start it. it feels like someone is shaking it from side to side. and once it drops btwn 850 and 1k it runs smooth as ever. is my timing off? i had the belt done 8k ago, could it have broken in at all and loosened and in turn threw my engine timing off? or is the ecu correcting it for me and retarding my timing automatically?
any help is appreciated
Old Mar 22, 2007 | 12:40 AM
badassb5's Avatar
Default RE: Engine shakes at startup
Is it running differently or throwing any codes?
Old Mar 22, 2007 | 12:46 AM
2KA4's Avatar
ORIGINAL: badassb5
it says OK at startup on the information screen. would i know if it was throwing codes when i turn it on? would there be a CEL? the car runs great after it drops to idle RPM which at my smog test was 814rpm
and the shake is not voilent, just like a rumbling like i have a silent V8 in there.
Old Mar 22, 2007 | 03:34 AM
SAudi's Avatar
Motor mounts?
Old Mar 22, 2007 | 03:50 AM
onepoint8tee's Avatar
maybe change your plugs. if they are fouled or the wrong heat range, it will be most noticeable on a cold start before they heat up. you might be getting slight misifres, could be that they arent frequent or severe enough to trigger a flashing cel. If it was engine mounts it would be noticeable all the time. get scanned for fault codes. You dont have to have a cel for there to be fault codes stored.
Old Mar 22, 2007 | 04:23 AM
2KA4's Avatar
ill try and change the plugs, see of that helps anything. it makes sense that they might not be gapped correctly and not getting an efficnet cold spark.
Old Mar 22, 2007 | 04:27 AM
ORIGINAL: 2KA4
Right
But I would get the ecu scanned for fault codes first, its free, and may point to a problem unrelated to plugs. But if you dont know when the plugs were replaced last, do it.
Old Mar 22, 2007 | 04:50 AM
2KA4's Avatar
Plugs were changed 8k ago.
Old Mar 22, 2007 | 12:56 PM
kpatz's Avatar
What kind of plugs are they? Copper? Platinum?
Old Mar 22, 2007 | 04:19 PM
2KA4's Avatar
ORIGINAL: kpatz
they came from the dealership so im assuming they are OEM
Yurchikrlg
Jun 18, 2011 01:55 AM
awebocompa
Mar 5, 2010 09:35 PM
huyaroo
Sep 12, 2007 03:37 PM
wilbrass
Mar 8, 2007 08:05 AM
apercele79
May 9, 2006 02:47 PM
