Engine Speed Sensor cause Limp?
Old Mar 8, 2007 | 07:03 AM
xxipsxx's Avatar
Default Engine Speed Sensor cause Limp?
Can an engine speed sensor cause limping?
Old Mar 8, 2007 | 07:06 AM
xxipsxx's Avatar
Default RE: Engine Speed Sensor cause Limp?
my speedometer stopped working and my miles stopped going up and then it stopped limping and was doing fine for a week or so so I kinda forgot about it and was just going to leave it being my car is ver problematic as it is. I went inside the store for a min came back out and it was misfiring like crazy so I changed the plugs and it helped a little. I'm not throwing any misfire codes just throttle pos sensor and throttle short to ground codes. Not sure how to fix those either. Taking the car to the shop in the mourning.
Old Mar 8, 2007 | 07:35 AM
techbod's Avatar
TP sensor is a likely candidate for your problem
[IMG]local://upfiles/12092/364BC83869804D50BF20E192FF031AAB.jpg[/IMG]
Old Mar 8, 2007 | 07:45 AM
techbod's Avatar
testing the VSS which is on the transmission in case you dont already know that
[IMG]local://upfiles/12092/937496FEF7A4413AA5FC2771DD3D9962.jpg[/IMG]
andrew456
Jul 23, 2013 11:49 AM
vtraudt
Nov 15, 2010 11:45 AM
twoaudis
Aug 9, 2010 02:15 PM
bshouler
Apr 17, 2009 08:44 AM
byouells
Jan 1, 2007 08:11 PM
