Engine thoughts needed
Old Sep 6, 2007 | 02:56 AM
drifter22's Avatar
Member
Default Engine thoughts needed
Hi , heres the deal I blew out my engine and now Im in the business of looking for a replacement, I found this one site MVPEuroporsts.com which sells new engines for my fwd 2003 A4 1.8t. Does anyone one no the reputation on these engines , such as the lifespan and problems that arise with it not being an original audi engine. Please help im getting ready to buy but i need to know that it wont go dead on me in a few months time. Any ideas suggestions about this engine would be appreciated. Here are the specs engine goes for $3500
Eurospec 1.8 Liter Short Block - 06B Type - Cast crank, 8.5:1 forged JE pistons, Eurospec rods for 2000-05 Audi A4 (AUG, AWM, AMB)
Eurospec 1.8T 4-Cylinder 5V Engines
Old Sep 6, 2007 | 01:44 PM
ironman's Avatar
Default RE: Engine thoughts needed
sounds good to me man
Old Sep 6, 2007 | 01:49 PM
cincyTT's Avatar
I'm make believe
What happen to your engine? You might not need to go through all that cost.
Old Sep 6, 2007 | 03:51 PM
drifter22's Avatar
Member
The engiine is gone theres is metal in the engine the rods are gone and the compression test showed zero in chambers 1,2,3
Old Sep 6, 2007 | 03:52 PM
drifter22's Avatar
Member
The reason for this post was because i wanted to know if anyone had ever bought an engine from these guys and what kind of reputaionj these engines have.
Old Sep 6, 2007 | 03:53 PM
onepoint8tee's Avatar
^yeah thats usually a good sign.
Old Sep 6, 2007 | 03:57 PM
cincyTT's Avatar
I'm make believe
i have heared good and bad things. So take that as you wish. You can go to "my car is f'd" thread and buy the engine linked there for $2500 and it is a built engine. You can also look at my thread in the TT section and have your engine bored out and stroked to a 2.0 or just use 83mm pistons and have a 1.9T. Check out qedpower.com for more info. Bob Q has everything you need.
Old Sep 6, 2007 | 03:59 PM
cincyTT's Avatar
I'm make believe
Also i will have my ATC rods (strongest stock rods) out soon if you want them for cheap to go with larger diam pistons since they are 20mm wrist pins like all the wiseco pistons.
Old Sep 6, 2007 | 05:15 PM
01afour's Avatar
sounds like a good candidate for that 2.7 swap haha. you should look into that though, its under the thread pretty interesting ebay find or something like that. CincyTT seems to think it should work so i say go for it, if you gunna be doing a swap anyway you might as well get a bigger engine. and its a true audi engine so theres plenty of people on here that can help you with any problems.
Old Sep 6, 2007 | 05:18 PM
cincyTT's Avatar
I'm make believe
Dont throw me under the bus here. It would take tons of fabrication to make it fit/run and far more than most are willing to pay for.
Tonyburke
Mar 8, 2013 06:21 AM
bshusted
Mar 2, 2013 07:14 PM
Jeff M
Jul 18, 2011 06:46 PM
s4clone
Dec 23, 2008 07:18 PM
jeanphilippeg
Jun 19, 2007 01:30 PM
