ENGINE WONT START!!!
Old Mar 8, 2006 | 07:43 PM
aRIf's Avatar
Default RE: ENGINE WONT START!!!
ORIGINAL: Jeff
ORIGINAL: aRIf
put it in 2nd gear.
even the radio works fine, it does not mean that you have good battery. starter need very high amp to turn.
y second?
This is what I always use if I need to do it. 1st is very short gear and dont wanna put to much pressure on it when car start to stall to run. Second gear looks little easy less stall and less pressure on the gear.
mjvss21's Avatar
so your saying that even if my radio running and power functions work i still could try jumping it? and wouldnt the started give some kind of warning of going? i never had a problem getting my car started before.
Old Mar 8, 2006 | 07:44 PM
mjvss21's Avatar
and in first wouldnt the tires just skid? maybe thats why he said second
Old Mar 8, 2006 | 07:45 PM
Jeff's Avatar
Zombie Defense Force
ORIGINAL: aRIf
ORIGINAL: Jeff
ORIGINAL: aRIf
put it in 2nd gear.
y second?
i guess i stand corrected makes sense now
Old Mar 8, 2006 | 07:47 PM
aRIf's Avatar
ORIGINAL: mjvss21
it happend to me (not with my audi) everthing was working fine but starter. Jump it with a big truck (they got powerful battery) and car did run.
Old Mar 8, 2006 | 07:49 PM
mjvss21's Avatar
alrihgt i will go drive the 96 superburban over there and give it a whirl
Old Mar 8, 2006 | 08:56 PM
mjvss21's Avatar
that didnt work, woiuld it need to be going pretty fast to pop the clutch and have it start wouldnt it?
Old Mar 8, 2006 | 09:16 PM
  #18
CRAZYHAWK's Avatar
Could be the ignition switch or selenoid.
Check if there are fuses in the primary starter circuit.
Old Mar 8, 2006 | 09:20 PM
  #19
mjvss21's Avatar
well i am going to have it towed to audi and have them look at it in the morning
Old Mar 8, 2006 | 09:51 PM
  #20
707782y's Avatar
You really shouldn't go to the dealer without test the battery or the starter first.
Most of the time, it's either the starter or the batter that caused it.
