Error code P0170
Old Jan 25, 2008 | 10:39 AM
drewsaudia4turbo's Avatar
Default Error code P0170
Hello all,
I need someone's expertise. I have a 2002 a4 1.8t and the check engine light came on. I went to Autozone to get the code read and the code is P0170
Fuel Trim Malfunction (Bank 1) A
Theguy at autozonesaid it could be the o2 sensor, MAF, Coil pack. They said the car is running lean, I guess not enough gas. The car runs fine. No rough idle, no stalling. The car is stock, no mods and no power loss. I hope you all can help me. I usually do my own work on my cars and I don't have a problem working on the car. I don't have enough money to take it to a shop and I don't have any warranty on the vehicle. Your help will be much appreciated.
Thanks!
Old Jan 25, 2008 | 12:46 PM
rccks96's Avatar
Default RE: Error code P0170
Did you put a K&N filter in?
I ask since a few days after I installed mine, I got that exact same code. A little while later, I had to replace my MAF. I'm using the stock air filter now.
DCAV8R
Jan 23, 2023 06:33 AM
fereidon
Jul 5, 2013 08:44 PM
murdox
Nov 21, 2011 11:42 AM
saved4use
Jun 19, 2008 10:43 PM
AgentX
Jun 1, 2007 02:03 AM
