EXPERT advice needed***
Old Oct 11, 2006 | 03:53 PM
  #21
Jeff's Avatar
Zombie Defense Force
Default RE: EXPERT advice needed***
hahah rofl funny you say that....
just went on the evo 3" turbo back with test pipe
ORIGINAL: G
dam pos audi !
i'm used to throwing 3" exhausts on my mitsus..........
Old Oct 11, 2006 | 05:36 PM
  #22
swift_A4's Avatar
damn that is hot
Old Oct 11, 2006 | 05:54 PM
  #23
dafrazi's Avatar
Did you remove the CAT?
If so, did you do the non-fouler mod for the rear O2 sensor?
Old Oct 11, 2006 | 06:10 PM
  #24
onepoint8tee's Avatar
3" is way too big for the little k03. You need some back pressure for the k03 to operate right. I would only use 3" exhaust on a really BT.. .25" makes a big difference in exhaust flow/back pressure, and you went up a whole inch from stock. I think you would still have problems even with a mbc, or a n75 race valve that limits spiking. If you dont want to change the dia. of the exhaust, you better be looking at a BT if you want things to run right. Shoulda used the search first!
Old Oct 11, 2006 | 06:29 PM
  #25
Jeff's Avatar
O snap SEARCH would of been good. unless your going bt. do you back fire alot with that exhaust?
Old Oct 11, 2006 | 06:38 PM
  #26
18T's Avatar
18T
vrum vrum
Old Oct 11, 2006 | 10:49 PM
  #27
G's Avatar
G
thanks dude, this is the kind of info i was looking for. i've learned from my current & past turbo cars bigger is better ie 3". this is my 1st audi i've modded & assumed it would be o.k. yes i have a 3" ss cat delete with the non fouler mod. check engine light has not been a problem at all. it's just that dam fuel cut. what do you think about flashing or chipping my ecu ? bigger injectors ?
installing that 3" cat delete was a major pita. what if i uninstalled the 3" exhaust & leave the cat delete then reinstall a 2.5" exhaust ?
ORIGINAL: onepoint8tee
mondo
Dec 9, 2012 10:57 AM
mondo
Dec 9, 2012 12:26 AM
JeniSkye
Mar 17, 2012 01:30 PM
rusky325i
Nov 4, 2010 08:54 PM
mjwhiat
Feb 9, 2010 09:14 PM
