Fast Blinker
Old Nov 2, 2006 | 04:52 PM
NuYorka103185's Avatar
Default Fast Blinker
I'm sure this post is somewhere else but everytime I read one like my issue it also had multiple other issues this is not the case with me. My blinkers just goes really fast when I turn on the right one. Left blinker works fine, hazard works fine and both left and right blink in unison at normal rate but do right blinker and it goes crazy. LEFT BLINKER: TICK.........TICK............TICK HAZARD: TICK.........TICK............TICK RIGHT BLINKER: TICK.TICK.TICK.TICK.TICK.TICK It is getting reallly annoying now can someone please help. By the way for troubleshooting purposes I checked to make sure all the light worked and they do. All bublbs work just fine and all light up the same brightness.
Old Nov 2, 2006 | 04:53 PM
aRIf's Avatar
Default RE: Fast Blinker
one of the signal bulb is out I believe.
Old Nov 2, 2006 | 05:18 PM
I'll check again thanks
Old Nov 2, 2006 | 05:30 PM
2007BLACK2.0T's Avatar
Normally its an indication that the bulb is about to go bad.
Old Nov 2, 2006 | 05:33 PM
onepoint8tee's Avatar
ORIGINAL: NuYorka103185
If its not a blown bulb, definately suspect the flasher relay. its sort of common.
Old Nov 2, 2006 | 05:38 PM
Flip's Avatar
It happened to me and it was a burnt out bulb.
Old Nov 2, 2006 | 05:42 PM
ORIGINAL: Flip
ya i agree thats normally the case, but if there reall is not a burnt out bulb then i dont know what else could be the prob if its not the flasher relay??
Old Nov 2, 2006 | 09:15 PM
mnaudi's Avatar
Check yur blinker fluid. (pulled than one on a chick in hs. Looked under the hood forever!)
I agree; burnt bulb
K1connection
Apr 8, 2008 03:22 PM
sntemp
Apr 6, 2008 03:44 PM
S4RiddeR
Sep 1, 2007 02:39 AM
duburban
Jan 18, 2007 06:31 PM
sandman
Oct 16, 2005 05:50 AM
