Fault code!
Well im outside right now reseting my "Service!" reminder... I scanned everything and got the following fault code. If anyone knows what its about please let me know, ill research it more when i get back inside. Thanks.
Address 01 -------------------------------------------------------
Controller: 4B0 906 018 Q
Component: 1.8L R4/5VT G 0005
Coding: 07051
Shop #: WSC 06335
1 Fault Found:
17964 - Charge Pressure Control: Negative Deviation
P1556 - 35-10 - - - Intermittent
Readiness: 0000 0000
Coding: 07051
Shop #: WSC 06335
1 Fault Found:
Could be N75 valve, diverter valve or wastegate.
My thoughts are that it is listed as intermittent. Clear it and see if it comes back before spending a lot of time researching it.
You can run tests, I believe on measuring block 114 with your vagcom
ORIGINAL: david9999
ORIGINAL: quattrosedan
well its about a five minute job to switch it around... so just change it to how it should be and see what happens.
So if there is play in the wastegate shaft it may be bad? What mileage is typical for an N75 valve to stop working?
And as far as mileage, my car 72k and still fine.....a friend has 90k and nothing wrong with his.....so I dont know there.
Ummm........the n75 and wastegate are not mechanically connected in any way. There is a vacuum line that connects them....and the 'wastegate shaft' should not be able to move at all........wait maybe on the k03 but on mine it doesnt open until 18psi.....so there is no way to move that with your hands with the turbo in the car.
VAG 17964 and P1556 are the same fault,
Turbocharger (TC) pressure - control limit not reached,
problem = TC wastegate regulating valve, intake leak, TC deactive.
[IMG]local://upfiles/12092/7A4CFFEA997444829990FE9FE72BE5D9.jpg[/IMG]
