Fault code!
Old Jan 13, 2006 | 02:18 AM
onepoint8tee's Avatar
Default Fault code!
Well im outside right now reseting my "Service!" reminder... I scanned everything and got the following fault code. If anyone knows what its about please let me know, ill research it more when i get back inside. Thanks.
Address 01 -------------------------------------------------------
Controller: 4B0 906 018 Q
Component: 1.8L R4/5VT G 0005
Coding: 07051
Shop #: WSC 06335
1 Fault Found:
17964 - Charge Pressure Control: Negative Deviation
P1556 - 35-10 - - - Intermittent
Readiness: 0000 0000
Old Jan 13, 2006 | 10:05 AM
david9999's Avatar
Default RE: Fault code!
Could be N75 valve, diverter valve or wastegate.
My thoughts are that it is listed as intermittent. Clear it and see if it comes back before spending a lot of time researching it.
You can run tests, I believe on measuring block 114 with your vagcom
Old Jan 13, 2006 | 12:33 PM
quattrosedan's Avatar
I used to have that problem.....so I decided to upgrade my turbo and now everything is A ok......lol....never found out what it was though.
Old Jan 13, 2006 | 02:05 PM
ORIGINAL: david9999
Thanks. Also, I have noticed lately that my vacume on my gauge is 25 at times. Its normaly about 10 when i start up and then 20 when its about warmed up, and then sometimes 25 at idle. Im going to replace all my vac lines this weekend just because there is one little hose on the top near the back of the engine that i wiggled one time and i could hear/feel the inside of it under the threads that it was cracking. OH wait... I just remembered I installed my DV in reverse because on a DV website it said if you have 710N it performs best in reverse instalation. Maybe thats it?
Old Jan 13, 2006 | 02:10 PM
well its about a five minute job to switch it around... so just change it to how it should be and see what happens.
Old Jan 13, 2006 | 02:14 PM
ORIGINAL: quattrosedan
Yeah i deffinately plan to do that tonight. I cant believe i forgot about that. So if there is play in the wastegate shaft it may be bad? What mileage is typical for an N75 valve to stop working?
Old Jan 13, 2006 | 02:31 PM
Ummm........the n75 and wastegate are not mechanically connected in any way. There is a vacuum line that connects them....and the 'wastegate shaft' should not be able to move at all........wait maybe on the k03 but on mine it doesnt open until 18psi.....so there is no way to move that with your hands with the turbo in the car.
And as far as mileage, my car 72k and still fine.....a friend has 90k and nothing wrong with his.....so I dont know there.
Old Jan 13, 2006 | 04:07 PM
Yeah i was speaking of the n75 and wastegate as two seperate things. So a small vacuum line connects them and not a larger diamater hose?
Old Jan 13, 2006 | 05:43 PM
techbod's Avatar
VAG 17964 and P1556 are the same fault,
Turbocharger (TC) pressure - control limit not reached,
problem = TC wastegate regulating valve, intake leak, TC deactive.
[IMG]local://upfiles/12092/7A4CFFEA997444829990FE9FE72BE5D9.jpg[/IMG]
Old Jan 13, 2006 | 06:28 PM
Thanks for the info.. Would a backwards installed DV cause a lack of presure in the "TC" ?
