fault code
Old Mar 1, 2005 | 07:01 AM
aznek's Avatar
Default fault code
hey everyone i got a fault code
01274 it said something about the motor flow and blocked with no voltage.
i also got the code 00849 i was wondering how could i fix the motor flow problem? and what should i do about the 00849 code. thanks.
Old Mar 1, 2005 | 07:05 AM
aznek's Avatar
Default RE: fault code
Oh i have a 2001 1.8t QM
Old Mar 1, 2005 | 09:36 AM
david9999's Avatar
What are you using to pull codes?
I can't find either
Old Mar 2, 2005 | 06:57 AM
aznek's Avatar
i used the vag. well someone else did it for me. but i'm not sure how to fix these problems.
Old Mar 2, 2005 | 09:28 AM
david9999's Avatar
Are you sure that you wrote the codes down correctly? I can't find them in my book.
If you are friendly with the person with the vag, have them pull the codes and download them to a file so you can upload them here along with the other information that comes off a vag, such as what system it is from. etc.
Old Mar 2, 2005 | 09:35 AM
aznek's Avatar
i looked on audiworld it said 00849 - S-contact at Ignition/Starter Switch -D- But why would this code come up?
and the other one is
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
liamol
B7 Models
Dec 5, 2011 03:41 PM
cardiffkid
Oct 13, 2008 12:52 PM
JohnnyS4
Oct 13, 2008 10:02 AM
adotjdot
Nov 16, 2007 04:48 PM
AudiTim
Aug 13, 2007 05:55 PM
