Fed up with Condensation!!
Old Oct 24, 2006 | 08:35 PM
VitaminB6's Avatar
Default Fed up with Condensation!!
Like other members have reported, I've had problems with condensation in the headlight covers. Again like others I've been told by Audi that this is "normal" and that they won't do anything about it.
This fall as the weather has turned crappy the condensation is back, with a vengence. Despite running with lights on 100% of the time, I've had condensation non-stop for about 3 weeks. What I wanted to know was - has anyone successfully gotten Audi to fix or replace their headlights? If so I'd appreciate it if you would tell me how you did it.
Thanks
Old Oct 24, 2006 | 08:43 PM
onepoint8tee's Avatar
Default RE: Fed up with Condensation!!
Id call Audi of America and bitch. you dont have a warranty right?
Old Oct 24, 2006 | 09:04 PM
chaos92287's Avatar
ya and they'll say its normal and their "fix" is to sell you brand new ones
Old Oct 24, 2006 | 09:55 PM
VitaminB6's Avatar
Still under warranty. I'll take a run at the dealer again.
Cheers
Old Oct 24, 2006 | 10:11 PM
xAUDIx's Avatar
Is there a way to take the headlight apart to clean the inside?
Old Oct 24, 2006 | 11:04 PM
bones's Avatar
I was told by Audi of Canada, and 2 other Audi dealerships that the headlights are vented and non-sealed headlights so a little condensation is normal. And that the condensation will burn off after a few minutes of driving. In your case though, seems like there's something wrong that you have condensation for 3 weeks straight. If you could keep this updated I would like to know how this ends up.
Old Oct 25, 2006 | 12:39 AM
Papachristou's Avatar
ill bet its ur fault for painting ur calipers
Old Oct 25, 2006 | 01:39 PM
VitaminB6's Avatar
Yeah, next thing will be the turbo will blow. Damn Duplicolor!
Old Oct 26, 2006 | 03:42 AM
dankhound's Avatar
The problem the dealers have is that audi wont pay them to do anything about it. And in most cases theres not much they can do about it. Theres a tech bullitin stating its normal and not to attempt to fix it. You can take the assembly out and check the seals to make sure they are ok as water getting in would cause excessive condesation. Also make sure the vents arent pluged up with leaves or such. You can also try taking it out and putting it someplace dry to try and get rid of as much mosisture as posible.
Pure_Xaos
Jan 14, 2009 08:53 PM
shortyxc
Dec 3, 2008 10:22 PM
jds26
Jan 21, 2008 04:13 PM
jds26
Jan 9, 2008 11:42 PM
jds26
Jan 9, 2008 10:30 PM
