First time radiator ?
Old Nov 14, 2007 | 07:49 PM
duburban's Avatar
Default First time radiator ?
Hey hey, i want to change my radiator but i've never dealt with radiator hoses. If the radiator i have needs new clamps how do i know what size to get? I could measure the diameter or course but is there a standard for this?
Old Nov 14, 2007 | 07:54 PM
auditech79's Avatar
Default RE: First time radiator ?
You shouldn't need new clamps but if you need new ones just use the screw clamp types which are much better anyways. Car manufactures don't use them because of cost.
Old Nov 14, 2007 | 08:05 PM
duburban's Avatar
Of course, thanks. One more thing, should i replace thermostat and coolant temp sensor at the same time? I shouldn't unless their dead but if i'll be able to get at them easy and their not expensive... Just trying to think ahead.
Old Nov 14, 2007 | 08:12 PM
auditech79's Avatar
The thermostat is behind the timing belt so you shouldn't worry about that until you hit 80k then replace everything all at once. You can get a repair kit at www.ecstuning.com
The coolant temp sensor is good to change if it has a black casing, you want either a green or blue one.
Old Nov 14, 2007 | 08:13 PM
hiwords's Avatar
thermostat is part of the timing belt change so not yet. but if u think u need to change ur timing belt, might as well do it while u got the front end half off. u can change the ECT though. it's on the passenger side behind the engine. go to audiworld.com and they have a superb writeup. dam he beat me!!!
gu9cci
Feb 22, 2020 12:50 AM
D9LEK
Apr 8, 2011 10:55 AM
mbonadio
Apr 5, 2010 05:24 PM
410ThirtyValve
Jun 1, 2008 12:14 AM
magendo
Feb 28, 2008 02:26 PM
