Flaming Hot Engine!!!
Old Jan 6, 2006 | 04:11 PM
dragondesigns's Avatar
Default Flaming Hot Engine!!!
God damn my engine is ****** HOT!!!!! I don't knw what could be wrong??? Everything around it heats up too, I can't even touch the hood or even the fender! Is this common in B5, 2.8L, 30v?????
NEED HELP!
[IMG]local://upfiles/11465/9D0BF5D1A0324197A355E1937B408D64.jpg[/IMG]
Old Jan 6, 2006 | 04:19 PM
Ultra sport's Avatar
Default RE: Flaming Hot Engine!!!
What is the tempurature gauge reading? How is your coolant level, do you have any leaks? A motor without coolant will get very hot pretty fast.
Old Jan 6, 2006 | 04:28 PM
Temperature is good. The coolan I believe is good, I have to check it after work. I think I might have some minor oil leaks... could that be the problem???
Old Jan 6, 2006 | 04:29 PM
onepoint8tee's Avatar
To directly answer your question.. That is not common... Just dont start hating when people give you suggestions on why everything is so hot, and is not a direct answer to your question of : "Is this common in B5, 2.8L, 30v?????"
Old Jan 6, 2006 | 04:34 PM
aRIf's Avatar
temp gauges(sensors) easy to fail for audis, so check your oil and cooland level asap.
Old Jan 6, 2006 | 04:36 PM
Onepoint.... are you gonna quit your crap or what??? Look at the other post and SEE who called who out first, then you can start putting your two cents in.
[IMG]local://upfiles/11465/8D0117121A2F434E8EE787F652AA021C.jpg[/IMG]
Old Jan 6, 2006 | 04:40 PM
ORIGINAL: dragondesigns
You know there is a correct way to add a picture into your sig? Im guessing you have low/no oil since you mentioned there is a leak. An oil leak wont cause your car to heat up like that unless it has all leaked out. I dont think drkeman was trying to really insult you, you seemed to have taken it too personaly.
Old Jan 6, 2006 | 04:41 PM
Thanks ARIF!!! Doing it right after work!!!!
[IMG]local://upfiles/11465/EF5F72275FE643E5919F3D4B8F4D6C5C.jpg[/IMG]
Old Jan 6, 2006 | 06:57 PM
kcryan's Avatar
i thought 1 pt was totally in line but whatev, also i agree check that oil asap.
Old Jan 6, 2006 | 10:11 PM
trailboss's Avatar
A stuck closed thermostat will also make your car overheat.
curtmon03
Mar 19, 2012 08:35 PM
curtmon03
Oct 4, 2011 07:49 PM
