Sponsored by:
Sponsored by:
Flange on the cat popped off. A few exhaust questions
Old 11-26-2004, 05:36 PM
1.8t20v's Avatar
Default Flange on the cat popped off. A few exhaust questions
The flange on the cat at the turbo side poped off a few days ago. Everything is welded and back together now. I was kinda getting used to it. It sounded like an old farm tractor. When I took the cat out and got the flange back on it didnt appear that there were any weld spots. Is this supposed to be welded or just a press fit? I just didnt see any weld marks anywhere. From doing some searching it seems to be a common problem.
Also what is the purpose of the down pipe? There is a mesh like thing half way down. What is this for? I didnt see anything special about it other than that but see people talk about it quite a bit. Why cant this be a straight pipe from the cat?
Old 11-26-2004, 05:57 PM
Default RE: Flange on the cat popped off. A few exhaust questions
The metal mesh is known as a flex joint. this allows the downpipe to flex to a certain degree so it wont break things (like any joints) when placed under stress.
Old 11-27-2004, 01:21 PM
1.8t20v's Avatar
Thanks, that makes sense. I have never seen this on other makes was why I though it was a little strange, unless it is something on newer vehicles.
Old 11-27-2004, 03:23 PM
no on most stock down pipes this is standered. but your right it is fairly new
Old 11-27-2004, 06:23 PM
Doose's Avatar
When I removed my intermediate muffler I would definitely have broken the pipe off at the cat if it weren't for that section of flex pipe.
Old 11-27-2004, 06:27 PM
audiboy1618's Avatar
Yeah, my metal mesh is fraying, im just going to get a downpipe and replace it instead of buying the oem part.
Old 11-28-2004, 12:41 AM
SlimChriz's Avatar
mine is a little sepperated I think Im gonna hollow out my cat when I replace it...
Think itll pass emissions?
Old 11-28-2004, 03:08 AM
david9999's Avatar
Ummm, nope.
Old 11-28-2004, 12:57 PM
1.8t20v's Avatar
I probably should have hollowed mine out when I had the chance. I was just going to go with a test pipe and new exhaust this spring anyway.
Why the edit?? [sm=dontgetit.gif]
ORIGINAL: 1.8t20v
woo hoo i have *******!!!
Old 11-28-2004, 02:57 PM
I was just showing a friend something
Quick Reply: Flange on the cat popped off. A few exhaust questions
