Can anyone here tell me how to change the light bulb on 1999 Audi A4/1.8T (basically how to access to it)? Also, what type and shape of bulb (if you have a pic for me too-much appreciated) Thanks.
6th Gear
Which fog lights do you have? Fogs built into the headlights or in the bumper. I'm going to assume in the bumper...
You have to pull the trim off and remove a few screws. The fog light will pull out. Then remove the plug and the rear housing cover. The bulb is a H7, which you can find at autozone.
Thanks for the info. Jestnomen. I bought it and changed the fog light (bulb). Just to clear it up a little for somebody who may looking for this info. 1) The bulb is H7-55 (same brightness as OEM), 2) Remove the trim (grill type) next to the fog light, 3) Remove the other trim in front of the fog light, 4) Remove three screws then pull out the fog light. By the way, this buld cost $16.99 + taxes CDN.
