foglights replacement on A4 B6 2002 ????
Old May 24, 2006 | 01:47 PM
jarocho77's Avatar
Default foglights replacement on A4 B6 2002 ????
has any aof you changed your bulbs on your car ??? I tried doing a search aon the DIY, Chop Shop, etc and could not find any details on on to do this. I want to replace the bulbs on my fog lights, how hard is it ??? got a link ???
Old May 24, 2006 | 02:03 PM
smokeU's Avatar
Default RE: foglights replacement on A4 B6 2002 ????
uhhh... i have an 01 but its pretty simple probly about the same... just pop the black plastic vent cover thing off. unsrew two or three bolts. remove housing. unplug harness (look for clip). unscrew housing. remove bulb. once you're in you'll see how to do this. just press metal clip down and press to the side. don't touch glass on bulb. put new bulb and reverse order. what kind of bulbs are you getting? color?
Old May 24, 2006 | 04:00 PM
jarocho77's Avatar
Without paying attention to what others think I'm getting yellow ones. I did research on the size and it looks like they are H11.My car is red and I've seen them in audi's before so I know they don't look bad.
Old May 24, 2006 | 04:03 PM
apercele79's Avatar
H11 is right
i got me the blue ones and they are hot cuz they match my headlights, also blue-ish tint
very easy to change them...once you unclip the tiny mesh stock grills around the bulb, it has a screw or 2 to the side of the bulb...if u unscrew it, you get to the actual bulb
i think it took me 3 min and i had never done it before...
Old May 24, 2006 | 05:56 PM
PandaXpress's Avatar
yea its an easy job u have H11 bulbs and u need a TORX screw driver to get the screws off i forgot what size though[&o] it was like size 5-8
Old May 24, 2006 | 06:43 PM
jarocho77's Avatar
Vielen Dank Burschen !!!!!!
Thank guys
Old May 24, 2006 | 06:58 PM
KarlMarx's Avatar
Take a look at www.Hoen-USA.com
H11's for your fogs...
H7's for both your high/low beams...
I went with the Xenon Match series, and I love them.
Zardos49
Jan 3, 2014 05:18 PM
vsunnyus
B8 Models
Oct 27, 2011 06:07 PM
mrmike454
Dec 14, 2010 01:06 PM
ravi76
Sep 7, 2008 07:14 AM
qwall
Dec 27, 2006 07:32 PM
