foglights replacement on A4 B6 2002 ????
has any aof you changed your bulbs on your car ??? I tried doing a search aon the DIY, Chop Shop, etc and could not find any details on on to do this. I want to replace the bulbs on my fog lights, how hard is it ??? got a link ???
uhhh... i have an 01 but its pretty simple probly about the same... just pop the black plastic vent cover thing off. unsrew two or three bolts. remove housing. unplug harness (look for clip). unscrew housing. remove bulb. once you're in you'll see how to do this. just press metal clip down and press to the side. don't touch glass on bulb. put new bulb and reverse order. what kind of bulbs are you getting? color?
Without paying attention to what others think I'm getting yellow ones. I did research on the size and it looks like they are H11.My car is red and I've seen them in audi's before so I know they don't look bad.
H11 is right
i got me the blue ones and they are hot cuz they match my headlights, also blue-ish tint
very easy to change them...once you unclip the tiny mesh stock grills around the bulb, it has a screw or 2 to the side of the bulb...if u unscrew it, you get to the actual bulb
i think it took me 3 min and i had never done it before...
Take a look at www.Hoen-USA.com
H11's for your fogs...
H7's for both your high/low beams...
I went with the Xenon Match series, and I love them.
