Foglights on Without Headlights
Old Aug 14, 2007 | 04:39 PM
cantdrive55's Avatar
Default Foglights on Without Headlights
Is there any mod that anyone knows about that can make it so I can flip my fog lights on without having my headlights or parking lights on?
Old Aug 14, 2007 | 04:43 PM
Belligerenceā„¢'s Avatar
Default RE: Foglights on Without Headlights
I think it's a vag option. canadian models use the fogs as daytime running lights though, so I'm set.
Old Aug 14, 2007 | 05:18 PM
ItsThat2.0T's Avatar
I don't know what year you have but....
http://audizine.com/forum/showthread.php?t=124534
Old Aug 14, 2007 | 05:47 PM
dan's Avatar
dan
Yes... there is a mod for fogs on without headlights...
Old Aug 14, 2007 | 06:11 PM
EVOLA4's Avatar
if you have vag-com you can change the country code and you will be able to have the foglights on w/o the headlights. i think the running lights stay on though.
Old Aug 14, 2007 | 06:28 PM
PandaXpress's Avatar
it depends on your year, i know the 2002 A4s you can change the codes wit a vagcom but they say the other years you might not be able to
Old Aug 14, 2007 | 06:38 PM
Lazer Viking's Avatar
if you have a b5, search independant fog light mod
Old Aug 14, 2007 | 06:42 PM
widgget's Avatar
please do a search before posting, there is alot of information about this floating around on this forum and vagcoms site and other audi guides.
But to answer your question. it can be done on both B5 and B6, i'm not sure about B7. B5 can be done with just vagcom. the B6 can be done a few ways, you can vag it and do some modification to the back of the light switch, or you can do just a physical modification, but it requires more modification then just the switch you also need to add some resistors and splices behind the dash, i don't remember the specifics. Again, do a search and you will find what you need, there are so many DIY guides for the A4s and more so for the 1.8t since it's used in VWs also.
Old Aug 14, 2007 | 08:35 PM
Ok so I figured out how to do it from a few DIY from AW/AZ/AF. But what I'm seeing is that people say that the rear fogs come on as well when you do the mod to make the fronts come on. Is this true? The rear fog will come on when you activate the front independently?
Old Aug 14, 2007 | 08:48 PM
what year is your car ?
