View Poll Results: A poll
Voters: 27. You may not vote on this poll
Forge 007 or APR R1?
ORIGINAL: onepoint8tee
PLEASE explain to us how a DV can foul spark plugs..... PLEASE...
An 006 is the same damn thing as a 007, just a bigger andslightly older design. Deffinate coincidence.
And what the **** is up with people blaming other things for killing coil packs?! Coil packs just die sometimes, it happens. More so on some types than others. There is no mod or other part under the hood that is going to kill a coil pack.... Damn.
ORIGINAL: chaos92287
a chip will increase the chance of blowing them (especially stock ones)
I like how people think packs fail when chipped. This is the only forum i have read that claim. I would put money and lots of it that people dont gap the plugs down to .028 nor get a heat range colder plug and still wonder why they keep getting misfires with new plugs/packs
Yeah unfortunately some members make up some bull **** theoriesbecause they happen to know a little something about a little soemthing. Its easy for a fool to fool a fool.
I think its just that people get on here and learn a few things and then assume theyve got it all figured out and can assosiate things to other things and eventually its all just a cluster **** of bad information... Thats when the ****** come in.
ORIGINAL: cincyTT
warrienty = push
faster response = r1
maintence = r1 (none needed)
adjustablility =r1 (none needed)
durability = 007
proven = 007
warrienty = push
durability = 007
proven = 007
faster response = in theory but not proven, if the spring tension used in the valve is greater than ours then the slightly decreased weight of the diaphragm is not a factor. Also the relationship between the surface area on either side of the piston/diaphragm is more important than the weight of the component itself. Also, guess what, fast response isn't always good. If the valve responds too fast than drivability goes to crap during boost to vacuum transitions and during partial throttle conditions.
maintence = Regardless of marketing, there are points of failure with any product. Servicing our valve periodically is NOT necessary but it absolutely will prevent you from ever being in a situation where our valve has failed on you.
adjustability =r1 (none needed) Absolutely disproved by units shipped with the incorrect spring, if spring tension were not an issue this would not have mattered. There is no magic spring that will work equally well in all situations, choosing one that works acceptably in a broad range of applications is nothing more than a compromise. Our design allows you the choice.
durability = 007
proven = 007
ORIGINAL: neilsa4
I removed my forge dv, & replaced it with a R1 as it cost me nothing thru a sale, & did this because thru years of working on all sorts of valves I have found diaphram valves usually only fail if they are in a caustic envoirment which heated air isn't. Kept my forge for spare just in case, hey it's better than stock.
ORIGINAL: cincyTT
why would you want a valve you have to maintain? Plus the R1 has seen over 40psi without failure on some 1.8t's without problems.
Im staying with my 004 beecause i love it to much to change..... that is until i finally get my BT, then the TurboXS R34 is going on the 1.8t. Nothing like a 34mm valve over a 25mm one.
When the time comes for the 34mm valve let me know, I have a 40mm valve for you to try if you are interested.
ORIGINAL: patty AT forge
ORIGINAL: cincyTT
I have stated it before and ill say it again. The problem is that some were sent out with the wrong spring on the R1. Once it is changed, it performs very well.
with that being said, my first R1 tore on my 1+ test drive after my flash... APRs customer service was somewhat lacking because i spoke with them several times about boost issues or programming glitch/mistake and they never mentioned defective R1s and it mooed!
however when i removed it and noticed the tear, i called them and explained my dissapointment and they took very good care of me so im happy with them now and i have a new R1 in for about a week now that doesnt moo and performs flawlessly and i dont think ill ever have to take it back out for anything.....
yes many people on the 'Zine had problems since we were the first to get them and someone did a huge group buy for $125 i think but those were all the ones with the wrong spring....
so i do love my new R1 and would highly recommend it, but i would buy it from APR directly and talk to keith and just explain you heard about the defective ones and u want to make sure it doesnt moo/tear!
just like cincy said.. all the new ones are perfect... several people on the Zine have been tracking with them several weekends in a row with APR 3+s and no problems!
and its a few milliseconds quicker and u never have to lube it up
ORIGINAL: Papachristou
