Found BOV.. DV in my car!??!
Old Jun 13, 2007 | 06:37 PM
Mosie84's Avatar
Default Found BOV.. DV in my car!??!
Bought my 99 a4 1.8t like 7 months ago and now i am currently replacing the catalytic converter and downpipe cuase they are shot... but during the reaplcement I noticed a turboxs BOV.. DV???? Did some reading and found those are not recommended for my vehical.... Is that one ok??? or should i rever back to stock???
Old Jun 13, 2007 | 06:45 PM
cincyTT's Avatar
I'm make believe
Default RE: Found BOV.. DV in my car!??!
if it is a turboxs type 25 (rbv-25), then it is made specifically for a VAG car. check here
Old Jun 13, 2007 | 06:50 PM
Lazer Viking's Avatar
should make you wonder what else is done to your car
id pop the cover off the ecu and see if you are chipped
Old Jun 13, 2007 | 06:51 PM
Mosie84's Avatar
I am pretty sure that is the one... but my cars still runs very rich... says there is a spring tension to adjust... would that fix the richness?
Old Jun 13, 2007 | 07:10 PM
theguy1084's Avatar
the DV has nothing to do with being rich. Its purpose is to relieve pressure between the throttle body and the turbo when you let off the gas so you dont stall out the turbo. maybe you are chipped I would look into that. Running rich is probably what killed the cat too
Old Jun 13, 2007 | 07:32 PM
Mosie84's Avatar
yeah i just got back in from outside... everything looks stock in the ecu...
NickBroderick
Mar 28, 2010 12:13 PM
moeron7
May 15, 2008 11:48 PM
225tt
Nov 5, 2007 08:15 PM
