FPR?
Old Oct 24, 2006 | 03:39 AM
onepoint8tee's Avatar
Default FPR?
Was looking at some parts at supremepowerparts.com and came accross this
It says if you have a 1bar chip or higher to use a 5 bar fpr.. was also reading about the neuspeed 1 bar chip they sell and it recomends a 5 bar fpr. How come GIAC or APR dont recomend a 5 bar fpr for their chips that are higher than 1 bar????? Anyone? Makes me want to try a 5 bar fpr!! I wonder if it will make me run too rich or what?? Stock fpr is 4 bar i believe...
Old Oct 24, 2006 | 03:44 AM
acetrebo's Avatar
Default RE: FPR?
If you drive like i do, then this may apply for you.
Recommended for vehicles that see sustained high speed/high RPM conditions such as open track events.
LOL, life is an open track event!
Seriously though, i drive the car hard a lot, but not constantly. But, maybe this would be worth swapping in for short periods of time when doing some drag runs or track day or something.
Old Oct 24, 2006 | 03:46 AM
AudiCross's Avatar
Default RE: FPR?
Well, from what i hear, those are only needed for B6 models. at least thats what GIAC and APR suggest.
Old Oct 24, 2006 | 04:03 AM
acetrebo's Avatar
Default RE: FPR?
From the site:
If you have a 1 bar or higher chip in your 1997-99 A4 1.8T
But I have no idea, I am just looking at what they have on the site.
I wouldn't think you would need it, unless you are BT.
Old Oct 24, 2006 | 04:04 AM
Default RE: FPR?
Hmmm i may try it out.... I guess im just itching for a mod... I really want the milltek exhaust.. Just trying to figure out a way to sabotage my stock one so breaking the news to the wife wont be so difficult haha.. grrrr... $800 is a lot to drop on it, but i dont have many choiced if i dont go custom...
Old Oct 24, 2006 | 04:13 AM
AudiCross's Avatar
Default RE: FPR?
i got u coverd!!!
here it goes. Find somewhere with a short steep speed bump. hit it too fast. fast enough where it bottoms out. hopefully, you will dent/crush a portion of ur exaust to an extent (before you try this, look under the car and see if the stock exaust is lower than other parts of the car. i know my aftermarket exaust is lower
and also. Borla is cheeper. and i like it. w00t
and for the mod. i know its hard. but id suggest saving for a k04. it takes longer. more tedious. harder to explain. but i think itd be worth it. but im a hypocrit. new breaks. to new suspension to a new clutch a flywheel! i cant wiat.
Old Oct 24, 2006 | 04:34 AM
Jeff's Avatar
Zombie Defense Force
Default RE: FPR?
just to let you know i ran stock fpr and stock fuel pump on my car
Old Oct 24, 2006 | 05:17 AM
chaos92287's Avatar
Default RE: FPR?
just go with a used exhaust. got my borla exhaust and Ecode test pipe for 600 shipped and i couldn't be happier with it
Old Oct 24, 2006 | 09:31 AM
david9999's Avatar
Default RE: FPR?
Don't drive over a speed bump fast. The most likely part to be taken out is your aluminum oil pan.
Old Oct 24, 2006 | 12:19 PM
aRIf's Avatar
Default RE: FPR?
Let me know, if you want to get rid of your exhaust, I have a solution
GIAC does not recommend 5bar, so you should ask them before you buy it.
I know Neuspeed recommends 5 bar tho.
