Front bumper?
Old Mar 30, 2007 | 12:06 AM
dvdcav's Avatar
Default Front bumper?
Iv been looking for a tutorial on how to take the front bumper off. Anyone know of one? its a 2003 a4 1.8t Thanks.
I want to put my intercooler on!!!
Old Mar 30, 2007 | 12:34 AM
x1rider's Avatar
Default RE: Front bumper?
This is for a 2002, pretty sure it's the same for your model year.
1. Jack the front end and remove both wheels.
2. Remove screws and peel the wheel well liner and you'll find the 3 nuts that retain the bumper on both sides, remove them.
3. Unclip the lower plastic part from the fender.
4. Remove the corner grills from the lower bumper and locate the 2 bolts (I think they are 6mm hex, not sure though), loosen them up, you'll be turning them for a long time.
5. Pull bumper off but be careful because you need to unplug the head light washer line and harness to the bumper.
Here are a few pics.
Bumper overview
The bolt you will see after removing the corner grills (pic and diagram)
Pic with all the attachment points (circled inyellow is the location of the nuts removed from inside the fender and in blue the verticalboltsloosened through the corner grills).
Circled in red is the headlight washer fluid line, circled in green is the harness to the bumper (fog lights, etc..)
Old Mar 30, 2007 | 04:16 AM
dvdcav's Avatar
Wow Thank you so much!!
Old Mar 30, 2007 | 04:18 AM
dvdcav's Avatar
Hey another question for you. When i put the intercooler on it looks like u have moved some lines. Is that the ac lines?
Old Mar 30, 2007 | 04:52 AM
luvin_the_rings's Avatar
is the stock b6 bumper big enough to fit an intercooler in there w.o cutting?
Old Mar 30, 2007 | 04:56 AM
PandaXpress's Avatar
supposetly this one
http://www.supremepowerparts.com/app...Intercooler_B6
Old Mar 30, 2007 | 07:20 AM
BadLuckAudi's Avatar
no thats the powerstearing cooler
ORIGINAL: dvdcav
Old Mar 30, 2007 | 08:34 AM
x1rider's Avatar
ORIGINAL: luvin_the_rings
The Awe FMIC requires very minimal trimming at the bottom of the bumper, the installation was very straight forward. You also need to trim the back of the corner grills. For my summer setup, I completely opened the front grills to show the FMIC because I spent like 20hrs removing the cast marks and polishing it.
This is what I started with:
After many hours of work:
After installation and grill trimming:
Old Jul 18, 2007 | 02:33 AM
sdsteez's Avatar
old post yes, but same with the b5?
Old Jul 18, 2007 | 02:49 AM
rj.r1005
Jun 28, 2013 09:13 AM
Zer0
Aug 22, 2012 02:19 PM
dbansal
Jul 13, 2008 12:50 PM
anya
Dec 27, 2006 09:30 AM
stockaayfore
Apr 4, 2006 03:23 PM
