front oxigen sensor
Old Apr 12, 2006 | 12:06 AM
fcanozo's Avatar
Default front oxigen sensor
I need to replace the oxigen sensor. Is it a easy job/ how to?
Old Apr 12, 2006 | 12:42 AM
BadLuckAudi's Avatar
Default RE: front oxigen sensor
I dont think its too hard to get to but theres 2 of them so the rear one is a bitch
Old Apr 12, 2006 | 01:31 AM
fcanozo's Avatar
it is the front one but Will I need the vag after replace it or will it reset by itself?
Old Apr 12, 2006 | 01:34 AM
dankhound's Avatar
Its a very easy job. Pop the hood. Look on the left hand side of the engine when looking from the front of the vehicle. There is an exhaust manifold and a turbo. Look more toward the rear of the vehicle and you will see the oxygen sensor coming out of the catalytic conveter. It will have 4 wires. All you need is an oygen sensor socket and a long ratchet and youll make short work of it.
The rear o2 is a little harder to get to but its not bad. Its just a little further down the exhaust than the front one.
Old Apr 12, 2006 | 01:38 AM
fcanozo's Avatar
So I don't need to go under the car?
Old Apr 12, 2006 | 02:17 AM
trailboss's Avatar
Nope, however if you dodn;t have the o2 sensor socket you can use a wrench but you have to remove the airbox which is easy. The rear 02 sensor is cake with a wrench dont even have to remove the airbox.
Old Apr 12, 2006 | 02:50 AM
silver_rings's Avatar
alot cheaper if you DIY than getting charged!
Old Apr 12, 2006 | 02:57 AM
fcanozo's Avatar
I will DIM tomorrow
Old Apr 12, 2006 | 03:38 AM
flyinb501's Avatar
Deff make sure you get an 02 sensor wrench. It makes it much easier. You can order one off ebay for cheap.
Old Apr 12, 2006 | 01:09 PM
Jestnomen's Avatar
6th Gear
Autozone also loans out O2 sensor sockets.
