Front Two Speakers Stopped Working on my 96 2.8
Old Jan 10, 2008 | 12:08 AM
Dima's Avatar
Default Front Two Speakers Stopped Working on my 96 2.8
They just stopped working for no reason, they were working perfectly. I just noticed it says bose when i turn on the system, but I dont think my speakers are bose because they have no markings. Regardless, Idunno how to access the fader at all or how to check the connections, what do I do?
Old Jan 10, 2008 | 12:58 AM
nordska's Avatar
Default RE: Front Two Speakers Stopped Working on my 96 2.8
did you change the radio or add anything new to your system,,,, or did it just flat out stop working?
Old Jan 11, 2008 | 08:43 PM
Dima's Avatar
flat out no reason.
Old Jan 12, 2008 | 05:33 PM
tdn's Avatar
tdn
Strange. First thing I would do is borrow two compatible speakers to put in your car to see if they work. If they do work, then you'll know you just need to replace speakers that both strangely stopped working. If they don't work, you'll know you have another problem on your hands. Perhaps a bad connection of some sort.
Good luck.
Old Jan 12, 2008 | 05:43 PM
jflores72's Avatar
To access the fader click on thetuner button until you get the fader and then adjust to see if they work...........
Old Jan 12, 2008 | 05:58 PM
MrFlippant's Avatar
If you have the radio code, maybe try resetting it? Disconnect the negative battery cable, then reconnect it and enter your radio code and see if it works then.
iancallaghan
Mar 11, 2015 12:06 PM
-rocky-
Aug 19, 2013 10:50 AM
quickdicy
Jun 17, 2012 11:55 AM
v6audi
May 13, 2009 03:37 AM
jonny29
Mar 13, 2008 04:50 PM
