Fuel injector seal?
I have a injector seal leack in my 1.8t, and i need to reseal them, couse i went to a mechanic and he is charging me 300 bucks for the work, but i wanna do it myself , to save money, wat tools do i need to take them out, becouse the mechanic was telling me that i need i special tool to take them out, is that true?
thanks for u help
thanks for u help
just did them. u DO NOT need a special tool of any kind. your mechanic is BSing u (typical scare tactic so he can land the job). Maybe he said HE uses a special tool, doesnt mean u need one. Mechanics have all kinds of "special tools".
As long as u have some workig knowledge of working on cars u will be ok. Just be cautious of how you disconnect things.
Basic procedure is: this is just general memory use a manual!
1 remove your gas cap to relieve pressure
2 remove plastic engine cover.
3 disconnect each fuel injector electrical plug (4)
4 remove 2 or 3? allen head socket bolts to fuel rail (attach rail to intake)
5 may have to move or disconnect accel cable to gain room
6 pull fuel rail with injectors straight out (will have ti use some force with a little jiggle)
7 you candisconnect fuel lines if u want to
will get a little gas messy-set up rags to catch any small residual fuel spills
each injector has two seals (top to rail and bottom to intake) the dealer sells them as a kit.
this job is not that bad at all
good luck
good luck
Probably want to disconnect the battery as well.
Is there a fuse on the a4 for the fuel pump? If so, you probably want to pull the FP relay/fuse, and turn the car over a few times to relieve the fuel pressure. I know you said remove gas cap, but is that enough?
IDK, I just have had to do this on other cars when working on injectors, not sure about the a4.
DJmart
Aug 3, 2013 11:08 AM
