fuel injectors
Old Apr 15, 2005 | 01:02 AM
cgv988's Avatar
Default fuel injectors
would it be worth the time and money to replace the stock fuel injectors on my b6 1.8? would i see any power gains? improved milage?
Old Apr 15, 2005 | 01:04 AM
Jestnomen's Avatar
6th Gear
Default RE: fuel injectors
not unless you are running a chip/turbo to support the injectors.
Old Apr 15, 2005 | 01:06 AM
cgv988's Avatar
im going to be running an apr stage 1 chip within the month. would it be worth it then? what performance gains would the injectors add?
Old Apr 15, 2005 | 01:18 AM
Jestnomen's Avatar
6th Gear
Injectors don't add HP. They only help deliver fuel. You don't need new injectors with just a chip.
Old Apr 15, 2005 | 01:20 AM
Doose's Avatar
I wouldn't worry about the injectors until you have both the chip and the turbo done. Your stock injectors can handle the remapped a/f mixtures incorporated into your chip and unless you are forcing a whole lot more air into the engine (ie the turbo) you won't really get much of a bang for those bucks. No pun intended.
Old Apr 15, 2005 | 01:44 AM
TomRitt's Avatar
Huge loss in performance if u get injectors with just a chip, plus you'll ruin your cat, o2 sensors, and washdown the cyl walls thinning out the oil like my motor does
Old Apr 15, 2005 | 03:46 AM
R_Tuned's Avatar
It's my understanding (now I'm just a noob so maybe I'm way off here) that when you are ordering a chip from APR you can get either a "Stage 1" or a "Stage 1+". The "Stage 1+" is designed to run with larger injectors, and is therefore tuned slightly different, which results in a power gain. At least that's the way it reads on the site. Here's a link to the site im talking about...
http://www.goapr.com/Audi/products/e...e_8ea418t.html
If anyone wants to read this and give an opinion on what it seems to say on the site it would be appreciated because I have actually be wondering about injector question myself.
Thanks in advance!
Old Apr 15, 2005 | 04:12 AM
TomRitt's Avatar
Yup you are correct, you only need injectors if your programming is set-up for them
JETSPEED333
Jun 7, 2010 08:15 PM
Longbow
May 12, 2010 09:42 PM
fuche
Oct 22, 2008 11:16 PM
pimphell
Mar 23, 2008 11:00 PM
TGPorsche96
Jan 22, 2007 03:32 PM
