Fuel Presure Reg.
ORIGINAL: trailboss
You should be running the oem FPR 4 bar, do the 5 bar if you have a k04 and giac software.
ORIGINAL: trailboss
Yes it would make you run rich.
The 5 bar is only for k04 giac cars and any other software that may use it. Why you think its runnig lean?
Do you have a boost gauge if so, whats it like, vaccum, boost spike, and what boost do you hold. Most people ie: NOOB's would think im crazy but it should be almost mandatory to pressure check the system to maybe find any leaks in the system. Stock your runnig 7-9psi and you jump it up to 16-17 there is bound to be leaks. When i first chipped my car i found 3 leaks. Not saying that that is your problem, internet diagnosing isn't the easiest thing without seeing the car. Do you have an aftermarket intake, that will make a sucking sound, also when its colder out i have notced on my setup the intake gets pretty loud.
