Fuel Presure Reg.
Old Dec 28, 2005 | 03:57 AM
onepoint8tee's Avatar
Default Fuel Presure Reg.
Should I get a 5 bar fuel presure regulator with having GIAC? Would it fit and what would happen good or bad? Thanks. What bar regulator is on it now?
Old Dec 28, 2005 | 04:02 AM
trailboss's Avatar
Default RE: Fuel Presure Reg.
You should be running the oem FPR 4 bar, do the 5 bar if you have a k04 and giac software.
Old Dec 28, 2005 | 04:07 AM
ORIGINAL: trailboss
So it has no affect with the k03 and giac? Would it make me run rich or something? Sometimes it feels like it runs lean but i dont get codes or anything.
Old Dec 28, 2005 | 04:24 AM
trailboss's Avatar
Yes it would make you run rich.
The 5 bar is only for k04 giac cars and any other software that may use it. Why you think its runnig lean?
Old Dec 28, 2005 | 04:30 AM
audiboy1618's Avatar
5bar you would run extremely rich with stock injectors in. It would fit tho.
Old Dec 28, 2005 | 04:31 AM
ORIGINAL: trailboss
Kind of hard to explain without experiencing it, but sometimes the engine sounds like its using and also performs like its operating on more air than fuel. I can hear the engine sucking in the air like crazy yet the torque and normal power that the chip makes isnt all there. I know its not limp mode, ive been there and know what its like.. This happens maybe 5 times a month for maybe one stretch of road at a time. Very rare but noticeable. Just sounds thirsty sometimes i guess? I notice it when im driving aggesively.
Old Dec 28, 2005 | 04:33 AM
Run some fuel injector cleaner before you do anything.
Old Dec 28, 2005 | 04:35 AM
ORIGINAL: audiboy1618
i did that about 1000 miles ago, should i do it again?
Old Dec 28, 2005 | 04:41 AM
And you saw no change with the fuel cleaner? 1000mi wont clog them up, what oct are you running?
Old Dec 28, 2005 | 04:46 AM
trailboss's Avatar
Do you have a boost gauge if so, whats it like, vaccum, boost spike, and what boost do you hold. Most people ie: NOOB's would think im crazy but it should be almost mandatory to pressure check the system to maybe find any leaks in the system. Stock your runnig 7-9psi and you jump it up to 16-17 there is bound to be leaks. When i first chipped my car i found 3 leaks. Not saying that that is your problem, internet diagnosing isn't the easiest thing without seeing the car. Do you have an aftermarket intake, that will make a sucking sound, also when its colder out i have notced on my setup the intake gets pretty loud.
