Fuel pump/filter help!
Old Feb 11, 2015 | 07:40 PM
kagflake's Avatar
Default Fuel pump/filter help!
I own a 2003 Audi a4 1.8t. I was hearing a noise coming from the rear passenger side of the car, so I looked up what it was and found out it was most likely the fuel filter. I changed it and the sound went away then the sound came back so I replaced the fuel pump.
This where i need help the noise is still there and now the engine needs to be cranked several times before it starts up. Ex. I have to turn it over five times stop then turn it to off position then try again and it fires up.
I replaced the fuel pump and filter myself. It was a really easy procedure. But im wondering if i was suppose to do some that I didn't do when replacing each component.i
I should note before I replaced the fuel filter the rpm needle would drop or jump around.
Is this fuel injection issues? Any help is appreciated thanks
skihigh2299
Oct 11, 2015 05:54 PM
skihigh2299
Sep 25, 2015 12:09 AM
DJmart
Aug 3, 2013 11:08 AM
sollyd25
Dec 2, 2011 07:39 AM
SmoothTT
Oct 9, 2009 08:10 PM
