funny... but what is a turbo timer?
Old Jul 1, 2007 | 03:16 PM
Sp33d07's Avatar
Default funny... but what is a turbo timer?
what is the purpose of the turbo timer and is it hard to install?
Old Jul 1, 2007 | 03:32 PM
FASTER's Avatar
Tech Slut
Default RE: funny... but what is a turbo timer?
it keeps ur car running after u take the key out 2 let the car "cool down". prevents damage to the motor and turbo by letting the cooling system run for a preset amount of time "like 5 min" is it hard? not too bad,,, r u any good with wiring?
Old Jul 1, 2007 | 03:36 PM
sean1.8t's Avatar
SEARCH.. every site that sells them has a description on what their purposes are..
it just allows the engine to run with the ignition off so that it cools the turbo down a bit before shut off. this way the oil that stops in the turbo doesn't coke(or basically sludge up)
not that hard to install and keep all factory conveniences like the keyless entry/locking system(in B5's only) on B6's and B7's it can be a bit harder to retain those features..
the turbotimer is not needed persay, but it is a convienience feature. if you don't want one then just don't boost for your last couple minutes of driving then shut the car off normal. and you'll be fine
Old Jul 1, 2007 | 03:37 PM
sean1.8t's Avatar
ORIGINAL: FasterA4ThanUrs
5 minutes?? more like 30-60 seconds depending on your driving before you pull the key out
Old Jul 1, 2007 | 04:47 PM
AteUrV8's Avatar
ya in my wrx and talon i let my car chill for about 90 seconds before i turned it off.
or like mentioned about if you dont boost your car the last couple minutes of driving than you will be chill as well.
on most turbo timers it has a self determining cooling time to where it adjusts itself compared to how hard your driving your car and when you come to a stop a light or something it will go down because its just idling.
sorry if that made no sense, im tired as shi*
Old Jul 1, 2007 | 07:07 PM
18T's Avatar
18T
ORIGINAL: AteUrV8
here we go again
Old Jul 1, 2007 | 10:27 PM
CLX's Avatar
CLX
Zombie Defense Force
I have my turbo timer set so my car is always running. It's the next best thing to remote start!
lukestaah
Jun 11, 2012 02:05 PM
njtrackstar
Mar 12, 2009 09:22 PM
Rhinop21
Dec 30, 2007 04:29 PM
flatlandfool
Feb 22, 2006 03:21 AM
kathan21
Oct 2, 2004 12:00 AM
