funny sounds from engine on cold start.
Old Oct 25, 2006 | 08:33 PM
FLEX_rs's Avatar
Default funny sounds from engine on cold start.
8e 1.8t 163 50k on clock
can anyone answer this
when i turn the engine on only from cold start (1200 rpm ) there seems to be a wyning noise ( def not turbo spool) until the engine begins to fall to idle at 900, then its all fine as even if i turn off and back on, i tried to hear out for the noise and it sound like its coming from somewhere neer the top left corner of the block.
Old Oct 25, 2006 | 08:36 PM
AudiCross's Avatar
Default RE: funny sounds from engine on cold start.
From that drscription, it may just be the normal noises. these engines have crazy temp. management systems and crazy emossion systems and they do lots of wierd things expecially when cold. its just your normal noises. but then agian, it may not be. i cant exactally from that description. does it idle well or dows it jump around?
Old Oct 25, 2006 | 08:40 PM
FLEX_rs's Avatar
idles normally , cuts off while dropping down
Old Oct 25, 2006 | 08:44 PM
FLEX_rs's Avatar
sound cuts off not engine
Old Oct 25, 2006 | 10:30 PM
bottled leaf's Avatar
same problem! I call it a flutter noise.
I think it is the throttle body, im gonna get some throttle body cleaner and see if it is fixes anything.
Tizhuan
Nov 6, 2010 05:54 PM
twoeightquattro
Aug 22, 2010 06:49 PM
duxbak99
Jul 13, 2010 09:04 AM
ReX
Sep 6, 2006 01:16 AM
Meradin
Oct 15, 2005 07:30 PM
