Fuse?
Old Mar 30, 2007 | 12:18 AM
eurodynasty's Avatar
Default Fuse?
so i have a sub box with a sub in my car and i dont know how the guy i bought it from wired it. i also have a pasport 8500 radar detector wired into my car so that when i turn the car on it turns on and off it goes off. today i think i blew a fus cause my sound system sounds terrible and the radar wont turn on. any idea which one it is? none appeared to be blown. also i accidently removed the radio fuse and put it back in, and now the radio just says SAFE and wont play music. help me please haha
Old Mar 30, 2007 | 12:25 AM
TDRILL's Avatar
Default RE: Fuse?
For the radio, you need a code. Hopefully you have it. I think it is in with the owners manual.
As for the fuse, a lot of times there is a fuse in the wiring (outside of your fuse box). As for where that fuse is... gets to looking. I would start under the hood near the battery. I have seen quite a few where the fuse is on the positive wire from the battery to the box. It would be like 8" away from the battery. If its not there near the battery, try following some of the wires for the box and see if you can find one.
I really don't know a ton about systems, but this is what I have seen on some of the less expensive systems I have encountered.
Old Mar 30, 2007 | 01:25 AM
BaconBait's Avatar
Default RE: Fuse?
Sometimes the radio code is in the spare wheel well.
Take a look around the fuse box area under the dash and look to see if there are any random wires that could be for your radar detector.
Old Mar 30, 2007 | 02:37 AM
Default RE: Fuse?
got the radio code part taken care of. thanks for the help guys.
as for the radar. the wire goes right past the fuse box towards the front of the car kind of right around the area of the pedals and then i cant see where else it leads to. where arre other fuses that arent in the fuse box? (for a 99.5 A4 1.8T fwd)
Old Mar 30, 2007 | 03:57 AM
a4 1.8t's Avatar
Default RE: Fuse?
it could be anywhere... audi puts them in the fuse box but god knows where the other guy wired his. take out that panel above the pedals and try to follow it farther
velvet jones
Jul 2, 2010 05:09 PM
rodel
Jan 22, 2009 12:25 PM
JcoyA6
Apr 24, 2008 01:30 PM
andrewk24
Mar 24, 2008 07:53 PM
brokenwire
Oct 20, 2005 12:11 AM
