Gas
Old Dec 12, 2007 | 10:18 PM
RW42891's Avatar
Default RE: Gas
+1
tdn's Avatar
tdn
Default RE: Gas
also, use the search feature.. this topic has been covered hundreds of times.
Old Dec 12, 2007 | 11:25 PM
afour's Avatar
Default RE: Gas
what a relief. u guys are the best!
Old Dec 12, 2007 | 11:40 PM
Bogie's Avatar
Default RE: Gas
ORIGINAL: nordska
i know this is going to get alot of people fired up im sure.... but im going to throw it out there. so try not to beat me up too bad!
what in the world would the point be of wasting tons of extra money for premium gas when it makes no noticable difference in the drivablity of the car???? i drive like a ton of miles a month so for me the cost difference adds up quick, and being in school and all i really need all the money i can get.
I ran 87 in my car for the last few years straight, all different gas stationsand therewasnever adifference in mileage (even before the chip) between 87 and 93. Ido run 93 in it now (only because it is $0.02 more per gallonthan 91) because of the higherboost with the chip. Thereisthe sameamount of energyin gallon of 87as a gallon of 93, the only difference the octane makes is the knock resistance - needed for higher compression ratioandforced air engines.Our cars run better on 93 and perform better, due to the knock sensor and engine control unit being able to adjust (advance) the ignition timing. Running 87 causes the engine to retard the timing, so you'll loose some performance, and possibly an unnoticeable drop in mileage. If you aren't driving hard, you probably won't notice any difference in mileage with 87.
Old Dec 13, 2007 | 04:50 AM
aberfitch82's Avatar
Default RE: Gas
i have a stock 2.8 and i notice the difference between using 93 and regular not as much get up with regular can deff tell the diff I refuse to use ne thing less than 93 better on the engine
Old Dec 13, 2007 | 12:18 PM
esandes's Avatar
Banned
Default RE: Gas
use top tier high octane. google up top tier.
Old Dec 13, 2007 | 05:50 PM
bob12312357's Avatar
Default RE: Gas
As per the manual in my car. The lowest octane to be used in your Audi must have an 87 pump octane
Old Dec 13, 2007 | 07:05 PM
  #18
ItsThat2.0T's Avatar
Default RE: Gas
ORIGINAL: nordska
Why would it say fill with 92 octane on my gas door if it wasn't necessary?!?! It's like drinking a 9$ handle of vodka, then drinking Belvedere, you'd notice a difference too...
Old Dec 13, 2007 | 07:22 PM
  #19
Default RE: Gas
ORIGINAL: ItsThat2.0T
ORIGINAL: nordska
I never said not 2 and i fill mine with 93 cause its wat we got around here. It won't do harm to run 87 though and Audi states this repeatedly in the manual.
