Gas brand preference, and does it matter?
Shell 91 but depends on the gas station I'm out. Found 3 close to me that are good 1 is a stright rip that is a shell but family owned so how knows. I just know I get crappy MPG from that one and am forced to use an octane booster to get the MPG to a decent mark. Other then that Shell and Chevron are my to of choice and I will go out of my way to find a good gas station.
why high ocatne?
well german n/a engines are highcompression which means they can compress a given amount of air more, octane is the resistance to ignition so if you have a lower octane it will ignite due to the heat like in a disel and cause engine knock which is very bad but that dosent ussualy hapen so you get bad performance and mpg
and every turbo car uses a higher ocaten because the turbo forcess more air into the engine
i use shell 93 bp 93 and mobil 93
and when i go to the track or when i make my friends pay for gas when we go to the southside to pick up i make them put in 100 octane from clark whic is 6 a gallon
yes our cars are tunned for higher octane ratings, anything less would be uncivilized, well not really but itll cause a CEL or severely retard the timing. also where you get gas matters, cheap isnt always better, i filled up at the dominicks petrol pumps once and my tank only lasted me to about 280 miles, whereas when i use shell or BP i get 300 with a small bit of spirited driving and i can usually still go another 20ish miles before the gas light comes on and i fill up.
