Gas smell?
Old Apr 18, 2006 | 12:54 PM
AYouDeeEye's Avatar
Default RE: Gas smell?
Anyone still around in this forum? I have the same problem where I only get the gasoline smell when the heat or a/c is on and I am stopped. Any suggestions for checking the evap system or is this something I should take to the dealer?
Old Apr 18, 2006 | 01:00 PM
techbod's Avatar
the problem with the newer cars is they built a plastic fuel tank and fuel lines, the part they forgot was the fuel pump sender/pump on top of the fuel tank "its iron" and rusts hence the smell of fuel
Old Apr 18, 2006 | 01:03 PM
techbod's Avatar
Anyone still around in this forum?? this forum is buzzing mate and getting fuller
Old Apr 18, 2006 | 01:15 PM
kaklexicon's Avatar
my gas problem (giggles) just randomly went away. there was a solid 2 weeks where i could smell it but now I don't smell anything at all...
Old Apr 19, 2006 | 12:51 PM
AYouDeeEye's Avatar
I took a quick look under the hood and found no signs of gas vapor but then again it was hard to tell because it was snowing! The gas smell only shows up on colder days, so I wonder if there is a loose fitting that leaks when it shrinks in the cold like a frightened turtle.
Old Oct 22, 2013 | 05:42 PM
49ers_A4's Avatar
Hey I have a strong gas smell coming from the driver side of my trunk on the in side of my 2001 a4 1.8 I have looked at every thing my tank and fuel pump and filler neck are all on the right side and there is no holes or leaks help me please!!!!!
Old Feb 3, 2014 | 01:10 PM
red-sled's Avatar
Hey there,
I have a similar problem with my '02 A4 3.0. Gas smell when it's full, goes away after I've used about a 1/4 tank. How did you diagnose the problem? I'm still poking around to see if I can pinpoint the issue.
thesponge
May 14, 2009 05:41 PM
jvegas08
Nov 18, 2006 10:36 PM
carlosgtn
Nov 17, 2006 05:44 PM
carlosgtn
Nov 16, 2006 11:02 PM
