Gear problem
Old Nov 20, 2007 | 04:52 PM
Darkmech's Avatar
Default Gear problem
I have noticed recently, that my stick seems to do some weird things under certain circumstances.
I was in 2nd gear this morning, and as I was accelerating, I noticed that the thing would pop out a bit. The car would still be in gear, but the stick itself pops out about half an inch (By pops out I mean towards Neutral).
The stick then goes down to it's original position when I let off the gas.
I know what this might be, and I'm really hoping it isn't what I think it is.
Anyone have any advice?
Old Nov 20, 2007 | 05:47 PM
Bogie's Avatar
Default RE: Gear problem
I think they all do that a bit.
Old Nov 20, 2007 | 05:58 PM
rafa_207's Avatar
mine does it too and when i have it in gear it moves to the sides too almost like in neutral just a little less
Old Nov 20, 2007 | 06:00 PM
pyropenguin's Avatar
Mine doesn't do it nearly as much as it did now that I have a snub mount.
Old Nov 20, 2007 | 06:07 PM
auditech79's Avatar
The tranny mount just suck, if you want to eliminate them you can get a custom brace to hold the tail housing of the tranny that will take it away. Up-grading the snub mount will also help, but it also makes the car have more vibration.
Old Nov 20, 2007 | 10:06 PM
Darkmech's Avatar
Alright, thank you! I was freaking out that my synchros might be the reason.
Old Nov 21, 2007 | 12:24 AM
David's Avatar
ORIGINAL: auditech79
How hard/expensive is that? Is the movement anything to worry about? I heard that the transmission will wear out faster if one rests one's hand on the stick when not shifting. Is this related to the movement we're feeling?
Thanks
Old Nov 21, 2007 | 06:10 PM
auditech79's Avatar
ORIGINAL: David
Thanks
Im sure there are companies out there that make braces out there for the tranny, resting your hand on the shifter **** is a myth, there is nothing it will do to make it wear out faster. However too much slop or play in the tranny mounts can shorten the life of the syncros.
burn357
Dec 13, 2011 08:46 AM
crd945
Jan 22, 2007 11:50 PM
kapil403
Sep 10, 2006 07:30 PM
rwdozier
Jul 7, 2005 05:47 PM
b6s4blackrusnak
Jun 21, 2005 02:33 AM
