Problem with 5th gear
Old Jan 21, 2007 | 11:55 PM
crd945's Avatar
Default Problem with 5th gear
When I am driving around 70 or 80 mph on the highway in 5th gear... If I accelerate and hold the car at a certain rpm my car will switch between 4th and 5th gears.. back and forth rapidly. This started after I chipped my car. Has this happened to anyone else?
Old Jan 22, 2007 | 12:11 AM
tooxtreme8813's Avatar
Default RE: Problem with 5th gear
yes this is somewhat normal for a chipped car, its called gear hunting
Old Jan 22, 2007 | 02:13 AM
Belligerenceā„¢'s Avatar
the best way to fix this is to sell your tip and buy a manual.[&:]
Old Jan 22, 2007 | 02:20 AM
Aspec's Avatar
Member
Are you using your tiptronic shifting or do you have it in drive? If you drive in "D" then use the trp shifting and that shouldnt go back and fourth I would assume. But you probably would have thought of that
Old Jan 22, 2007 | 09:11 AM
david9999's Avatar
Happens to me
Old Jan 22, 2007 | 11:44 PM
Amze's Avatar
ORIGINAL: Belligerenceā„¢
Perfectly said my friend.
Old Jan 22, 2007 | 11:50 PM
onepoint8tee's Avatar
happens to me in tip mode too.. also happens to brrman... not cool. so i downshift to fourth right when i know its about to happen so i still feel like i have conrtol over what is going on. I psyc myself out basicaly. I was chipped for about a year before it started happening. Just to sum it up:
In 5th on the highway (only speeds over 60mph) if i give it 1/4 throtle or more is automaticaly downshifts to 4th gear in tip mode, when it shouldnt. Does it in D mode for me too, when for the amount of throtle that is being used, it really shouldnt, it should hold the gear. Im used to it now and youll get used to it too... OR buy a manual.. Thats a good idea...
Some people in other forums complain about it too.. A tip chip does not cure it btw.
burn357
Dec 13, 2011 08:46 AM
Darkmech
Nov 21, 2007 06:10 PM
kapil403
Sep 10, 2006 07:30 PM
rwdozier
Jul 7, 2005 05:47 PM
b6s4blackrusnak
Jun 21, 2005 02:33 AM
