GIAC K04 Software is in!
Old May 23, 2006 | 01:45 AM
JettaRedII's Avatar
Default GIAC K04 Software is in!
And the car is simply awesome! The boost peaks at 22 psi and holds steady at 19-20 psi. However, when I hit about 5000 rpm under load, the boost "sometimes" (about half of the time) becomes very erratic.
Just got it done this afternoon, so I haven't had much of a chance to try to diagnose the problem. But here is what I observed:
1. High rpm with little load (~12 psi)--no problem.
2. Low rpm (<4500 rpm) with high load (~19 to 20 psi)--no problem.
3. High rpm (>5000 rpm) with high load (~18 to 20 psi)--erratic boost.
On the phone with the shop I'm told my MAF may be marginal and is intermittently weirding out (my words). I cleaned it tonight and may just order a new one, but has anyone else experienced this?
Old May 23, 2006 | 01:49 AM
PandaXpress's Avatar
Default RE: GIAC K04 Software is in!
did u get larger injectors or did u get the basic K04 programming
Old May 23, 2006 | 09:37 AM
JettaRedII's Avatar
ORIGINAL: PandaXpress
I don't know if it's "basic" K04 programming because I did need a 5 bar fpr (which is in), but I did not go with larger injectors.
Old May 23, 2006 | 11:23 AM
north5995's Avatar
I thought you had to get the larger injectors for the K04 programming?
Old May 23, 2006 | 01:32 PM
brrman's Avatar
not necessarily
Old May 23, 2006 | 11:20 PM
Beer Mod's Avatar
Just the K04 P-16 file gets the injectors right?????
Old May 24, 2006 | 12:25 AM
david9999's Avatar
How many miles since you changed your fuel filter?
Old May 24, 2006 | 01:41 AM
JettaRedII's Avatar
ORIGINAL: david9999
Ummm, what's that?
J/K I bought the car used and have not changed the filter. It has 58k on it now. Sounds like my Saturday is planned for me!
Old May 24, 2006 | 02:25 AM
a4orce1's Avatar
You can do either larger injectors or a bigger fuel pressure regulator.
Old May 24, 2006 | 03:33 AM
ORIGINAL: a4orce1
no point he doesnt have the correct programmin for it
