going above 1BAR (14.7psi)
Old Sep 11, 2007 | 09:07 PM
  #21
onepoint8tee's Avatar
Default RE: going above 1BAR (14.7psi)
ORIGINAL: kemp_travis
well it has an S4 FPR, and S4 coil packs if that makes any diff.
but im not right at 14psi, i would say im at about 13.5 or less.
but i know what detnation is, and it has yet to "bogg" or go to limp mode, it has been running great ever since i did it (2-3 weeks ago), and no i dont have a BOV.
An s4 uses a 4 bar fpr just like your a4, so that wont do anything. Im surprised s4 coil packs would work on an AEB engine. The point of all this is that because you have a pre 2000 engine, limp mode will not save you from blowing your engine up because you dont have a map/boost sensor. Even if you arent having problems, you still arent achieving what you think you are or hope to achieve by hooking up a mbc and cranking it up.Check the classifieds for a used chipped ecu if money is tight. Sometimes people will want your stock ecu for their chipped ecu + $200. So it can be affordable to do it the right way.
Old Sep 11, 2007 | 09:11 PM
  #22
cincyTT's Avatar
I'm make believe
ORIGINAL: onepoint8tee
Your not a Father are you? I would be scared for you kids
  #23
kemp_travis's Avatar
ok....but i thought i had the map sensor?...if not wht the hell is tht **** on my air box?
and even if ive never hit limp mode or fuel cut on almost 14psi, that still is bad?
anyone have an explaination for the fire bal...
Old Sep 11, 2007 | 09:12 PM
  #24
im not a father if your asking me...no were NEAR of age...ha
Old Sep 11, 2007 | 09:15 PM
  #25
oh, and dumb question, but i have no idea wht it is...what is the blow off valve looking thing on the intake of the turbo???
Old Sep 11, 2007 | 09:17 PM
  #26
cincyTT's Avatar
I'm make believe
Thats the MAF on the airbox, the MAP is on the ic. Im sure your fine, seems like you are getting more than enough gas if you shoot it out the tailpipe
Old Sep 11, 2007 | 09:19 PM
  #27
cincyTT's Avatar
I'm make believe
Thats the dv, and i wasnt asking you about being a father
Old Sep 11, 2007 | 09:21 PM
  #28
ORIGINAL: cincyTT
I like to crack em into shape while their young
Old Sep 11, 2007 | 09:22 PM
  #29
and why do i have like an s-line, or s4 steering wheel and shifter, is my car maybe a dif model than i think?
Old Sep 11, 2007 | 09:23 PM
  #30
auditech79's Avatar
Who knows whats on your airbox, it could be your ICM or leaf from a tree for all we know, post some pics!
