Grease the sunroof rails!
Old May 23, 2007 | 07:07 AM
david9999's Avatar
Default Grease the sunroof rails!
Just a friendly reminder to all those with sunroofs.
Now that summer is here, grease the sunroof rails with white lithium grease so that your sunroof doesn't get stuck.
While you are up there, check the drain holes and make sure they are not clogged, otherwise your car interior can get wet when it rains.
Old May 23, 2007 | 07:53 AM
Amze's Avatar
Default RE: Grease the sunroof rails!
Thanks for the reminder, always wondered what grease I was supposed to use.
Will do, don't want a broken sunroof
Old May 23, 2007 | 08:02 AM
ironman's Avatar
The grease is this something i can get at pep boys??
Old May 23, 2007 | 09:21 AM
CRAZYHAWK's Avatar
I use silicone spray, it is cleaner.
Old May 23, 2007 | 09:40 AM
kpatz's Avatar
I have lithium grease spray, would that do the trick? And what's the easiest way to check the drains?
Old May 23, 2007 | 09:56 AM
chitownA4's Avatar
i wish i used lithium grease..i use normal "get ur a$$ dirty as hell" grease..now everytime i open it, it smells like grease..and im too lazy to clean it because one i dont want to...and two i dont wanna get that **** everwhere..
Old May 23, 2007 | 10:23 AM
silveraudi01's Avatar
hye along these same lines does anyone know of a good diy on cleaning the contacts of the sunroof switch mine has been tempermental lately and i want to fix it.
Old May 23, 2007 | 10:45 AM
AdamBlackB5's Avatar
thanks for the tip.....where are the drain holes located?? i have a 96 2.8 quattro
Old May 23, 2007 | 12:56 PM
CRAZYHAWK's Avatar
Use RadioShack Contact Cleaner on the switch.
Schoey85
Sep 20, 2012 11:41 AM
tariqahmad
Oct 16, 2009 11:49 AM
Buttery Cracker
May 9, 2007 07:28 PM
Altt180
Nov 17, 2006 07:31 AM
tmack
Aug 31, 2005 07:14 PM
