GT 3071-WG Project !!!
Finally I have time to took some pics and post my project. I upgraded turbo GT3071-WG (4" inlet), ATP manifold, EVO FMIC, 580cc injectors, JE Pistons (82mm), Pauter Forged Rods, Spec Stage 3 Clutch, B&M Short Shifter, additional Bosch In-Line Fuel Pump (255l/h), 3" MAF housing, 3" full back exhaust without cat (soon bigger downpipe), engine and head fully rebuild (I already post the rebuilding of the engine).... It is like new engine. At the moment the car is making 250 HP, because I still need to change ECU with EFI Stage IIc, then I will turn the boost and go for 450 HP. Here are some pics, on the pics is missing heat shield between turbo and air filter, now already installed.
The car is running great and you can already fell that the turbo will go nuts
I will post the dyno when new ECU will be installed. Can't wait to change ECU.
Comments are welcome!
[IMG]local://upfiles/5369/28F5DA15B67E45C9B0A07BB5F73D47C5.jpg[/IMG]
I will post the dyno when new ECU will be installed. Can't wait to change ECU.Comments are welcome!
