GTRS Turbo
Old Jan 25, 2008 | 05:44 PM
  #21
MasterV's Avatar
Default RE: GTRS Turbo
Thanks for the Info!
Old Jan 26, 2008 | 01:53 PM
  #22
MasterV's Avatar
sorry about all the questions but if I were to do the T3/T4 turbo, I know I need a manifold,ecu upgrade,injectors,test pipe, but do I need different oil lines and a wastegate to go alongwith it?
Old Jan 26, 2008 | 04:53 PM
  #23
chaos92287's Avatar
oil lines should always be replaced when you replace a turbo. and if you run an external wg, you will have to buy one, and get a manifold with the correct plumbing.
Old Jan 28, 2008 | 03:03 PM
  #24
MasterV's Avatar
I went on ATP to see if I could put together a T3/T4 setup. I can find the manifold,Turbo,and wastegate but they don't seem to have all the gaskets like turbo to manifold,and turbo to cat also they have a fitting to use stock oil lines is this a good idea? One more question will the atp inlet hose fit a T3/T4 turbo if not where can I find these items?
Old Jan 28, 2008 | 03:57 PM
  #25
cincyTT's Avatar
I'm make believe
Dont run gaskets in those places. They blow and arent needed. You want a -4 oil line and fittings. They sell the correct length and a adapter for the stock block to connect to the oil line. Dont run stock lines. The tip may work, but its easy to make your own
B5Project
Feb 9, 2009 07:53 PM
southcoast
Feb 1, 2007 06:02 PM
quattrosedan
9
Nov 5, 2006 03:18 AM
germancarmaniac
Oct 25, 2006 12:45 AM
Buttery Cracker
Apr 28, 2006 12:42 PM
