Has anyone put S4 stock Suspension on an A4?
Old Nov 18, 2005 | 08:49 PM
BFlan2001's Avatar
Default RE: Has anyone put S4 stock Suspension on an A4?
please post your results in this thread, karl. i'm very interested in seeing the outcome of this.
docurley, your car is BEAUTIFUL! but how is it an oem kit if it's not an avant? how much did that run you? were you able to do it all yourself? i have so many questions for you!
Old Nov 19, 2005 | 01:28 AM
CnB's Avatar
CnB
according to the previous owner my A4 has S4 suspensions fitted
though i think its still to high rides nice tho
but i might change them coming summer when i got my new wheels
Old Nov 19, 2005 | 03:33 AM
Karl's Avatar
I will do a comparison, with pics of measurements before and after. Front and back, then a few weeks later after it has settled
Old Jun 16, 2007 | 06:49 PM
S_R_N83's Avatar
I'm really bringing this thread back from the dead...
I got an opportunity to get a B5 S4 Suspension for really cheap so I went ahead and bought it. I have an 01 A4 1.8t with Non-sports suspension.
Since this thread, which is a few years old, has anyone actually done or figured out if using the s4 suspension on the 1.8t will work? Will it raise the car because of the weight difference? lower it?
I can't afford to go too low because of the road conditions and winters here, and dont want to shell out the money for coilovers so I'm trying to figure out if this would be an easy solution.
Let me know what you think.
Old Jun 16, 2007 | 07:03 PM
auditech79's Avatar
I have a B5 S4 and bought the Stasis coilover kit and gave my old S4 suspension to another friend of mine that had a B5 A4. After he installed it it was only slightly lower and a pinch stiffer than the stock A4 suspension. Although if you stare at it long and hard you will notice the front suspension is a couple of mm higher than the rear but you would never notice un-less you were staring at it. I think the total drop was somewhere around 10mm which isn't that much.
Old Jun 16, 2007 | 07:08 PM
sean1.8t's Avatar
ORIGINAL: BFlan2001
the boys on aw are wrong dude, 300lbs isn't going to make it higher at all. think about it this way....how much does an s4 drop when two average sized people (~300lbs) are sitting in it? i'd say, maybe 4-5mm....so figure your car will sit 4-5mm higher than a stock s4....and the stock s4 suspension sits at about the same height as the sport a4 suspension on their respective cars, right? so, if you do the math (my math, anyway), your car should drop a good 15mm from where it sits right now.
no, the boys on AW are right. the additional weight is in the motor. WAY up front. when two people get in the front seats is puts the additional weight of the 2 people in the center of the car. balanced between the front and rear.. but if you have those two people sit on the hood, right over the wheels, you'll see the suspension(A4's or S4's) lower signifigantly..
but to redgoat. the S4 suspension will be higher in the front. but it will be a little stiffer due to the stiffer spring rates.. i could be wrong though, because you do have the USP suspension, which could be close to the S4 suspension as far as spring rates go
Old Jun 16, 2007 | 07:10 PM
sean1.8t's Avatar
nevermind, i just notice the age of this thread.. i HATE necro-bumping. just create another thread people[:@]
Old Jun 16, 2007 | 10:08 PM
  #18
18T's Avatar
18T
ahh this is from the age when redgoat had his old a4...
why would you bring it back i dont know.
luxuryimports1
Jun 23, 2009 11:11 AM
H-audi
Mar 16, 2009 09:56 AM
Dstranks
Aug 14, 2006 02:29 PM
mazzeo
Sep 15, 2005 04:42 PM
