Has this ever happened to you?
Old May 9, 2006 | 04:50 AM
Trey25's Avatar
Default Has this ever happened to you?
Ok my rear brakes are worn badly and squeaking a little so I decided to jack em up and have a look before I order new rotors and pads. Anyways I take the wheel bolts off and the tire won't budge[sm=WTFsgign.gif] I've done this before so I know I'm not F_ing it up, just to make sure I try the others. Come to find out all four tires are rusted stuck to the damn rotors[:@] I don't have a proper jack or stands to be under the vehicle bangin way so it'll have to wait.
Old May 9, 2006 | 05:04 AM
A4 the Quattro's Avatar
Default RE: Has this ever happened to you?
tires are made of rubber...they cant rust but i feel ya.. my lugs are on so tight that i cant get my wheels off period.. gotta take the car somewhere and get them taken off and put back on ..
Old May 9, 2006 | 05:06 AM
BadLuckAudi's Avatar
all you need is a BFH and you can get the wheel off the car no prob
Old May 9, 2006 | 05:46 AM
Trey25's Avatar
Well I'm going to the stealership thursday to VAG my ABS so I'll ask to them to do it for me. They'll probably charge me to do that ****...bastards lol
Old May 9, 2006 | 06:02 AM
AteUrV8's Avatar
rusted to your rotors??? huh....??? that gave me a good laugh
Old May 9, 2006 | 06:27 AM
techbod's Avatar
this is quite common, you have alloy wheels and the hub is steel together if left long enough they will seize together that's why the use spigot rings but you should be removing the wheels approx every 1,000 miles and re torquing them to prevent this from happening and a good idea is to put some copper grease where the spigot ring comes into contact with the hub
Old May 9, 2006 | 06:49 AM
FantasiA4's Avatar
Yah, the same thing happen to my rear wheels. Spray WD40 or put some grease on it before you put the wheels back on.
Old May 9, 2006 | 06:52 AM
or just keep a big hammer in your car to get them off when ever you want
Old May 9, 2006 | 07:14 AM
techbod's Avatar
yep big hammer because all the dealers will do is knock they off with a hammer and give you a bill that will feel like you just been hammered lo
of course they hit the tyres not the alloysl
Old May 9, 2006 | 07:36 AM
Trey25's Avatar
[sm=exactly.gif] lol
