headlamp washers...pump or nozzle???
Old Feb 9, 2005 | 02:40 PM
thintzen's Avatar
Default headlamp washers...pump or nozzle???
does anyone have any idea how i can tell whats wrong with my headlamp washers? how do i know if its the pump or if its the nozzles or motor itself? when i pour in washer fluid....it fills up but eventually will start to leak at the pump for the headlamp reserve. when i pull up nozzles manually and play with them, i can hear and see the fluids escape throught the pump. is there any way to diagnose one or the other?
HELP ME!!!
Old Feb 9, 2005 | 02:49 PM
Jestnomen's Avatar
6th Gear
Default RE: headlamp washers...pump or nozzle???
If you want to get to the bottom of this, you are going to have to remove the wheel liner. Then have someone turn on the system, and you watch for leaks.
http://www.audiworld.com/tech/misc28.shtml
Old Feb 10, 2005 | 12:22 AM
david9999's Avatar
Most likely it is the nozzle rather than the pump itself.
I just got a used nozzle to install. Pricey little bugger.
Old Feb 10, 2005 | 12:23 AM
Jestnomen's Avatar
6th Gear
I wouln't think they would both be FUBAR'd.
Old Aug 13, 2008 | 02:59 PM
mstout's Avatar
Where were you able to find a used nozzle? I've been looking all over - no luck. Obviously I'm not looking in the right places. Thanks for any info.
jim-bo
Aug 20, 2011 05:10 PM
BoostedA4
Apr 2, 2011 02:21 AM
thintzen
Jun 9, 2010 11:55 AM
miabhai_freaked
Feb 14, 2006 09:08 PM
thintzen
Feb 12, 2005 01:30 AM
