Headlight "Dipping"...
Old Nov 20, 2005 | 12:17 AM
ZedEx's Avatar
Default Headlight "Dipping"...
Great, so I get the "Right Headlight Dipping" error message on my cluster display right before heading out of town last night. So my right headlight is out... Checked Germanpartsonline.com... $147.95?!
So, is there an alternative to spending over $300 on a set of bulbs? What would you guys recommend?
Old Nov 20, 2005 | 01:09 AM
ZedEx's Avatar
Default RE: Headlight "Dipping"...
... Guess I'm screwed.
Old Nov 20, 2005 | 11:43 AM
david9999's Avatar
I'm assuming you have Xenon?
I'm also assuming that you have checked your headlight and made sure that it is out and that the connection is OK?
Old Nov 20, 2005 | 06:57 PM
ZedEx's Avatar
I thought it was the headlight... Until I found THIS.
Soooo... Do the headlights have a relay somewhere?
Old Nov 20, 2005 | 10:46 PM
david9999's Avatar
Remove both bulbs and switch sides.
If the bulb is out, then the problem will now be on the other side. If it is the harness or other connection, the right one will stay dipped.
Old Nov 21, 2005 | 12:28 AM
ZedEx's Avatar
This was the first thing I was going to try this morning... Rain, all day. [:'(]
So I'll give that a try tomarrow. I appreciate the input.
Old Nov 21, 2005 | 12:29 PM
ZedEx's Avatar
Great, now my RIGHT FOGLIGHT IS DIPPING! I should have stuck with Hondas! [:@]
leesy123
May 13, 2022 08:34 AM
hottrod656
Nov 19, 2013 08:18 AM
boostin_A4
Sep 12, 2009 05:15 PM
3.0AmuletA4
Jan 6, 2008 11:59 PM
aublutiger
Jan 5, 2008 05:02 PM
